Dome Light Wiring Pictures?
Old 10-18-2009, 12:07 AM
95PhoRunner's Avatar
Does anyone have pictures of the wires that go to the dome light? My dome light is not working so I removed the dome light assembly and found the the previous owner had unplugged it because they had put in a monitor. So I found the RCA cables and a really thin black and white cable on one side and a single black cable on the other side. I don't want to short anything out. Does anyone know which wires I need to hook up the dome light so it works?
Thanks
95Phorunner
Old 10-18-2009, 01:29 PM
Jay351's Avatar
The two wires are both power wires. One will be constant power (use a multi-meter to test) and the other will be switched power for when the doors open.
The dome lines ground through their mounts
Old 10-18-2009, 08:29 PM
Thank you Jay! This morning before I saw your post I hooked up those two wires to the dome light switch and wala power! Before I could screw the switch in to the slot my buddy broke the switch. Doh! I'm calling the dealer tomorrow to see how much they want for one.
smthwsn357
12-04-2023 02:08 AM
XtraCab
04-12-2020 05:25 AM
Johntom240
7
07-13-2015 12:18 AM
msane99
07-11-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Dome Light Wiring Pictures?
