| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Does the time belt in a 3.0 give warning
#2 (permalink) |
From my experience, belts typically do not give any warning they are going to fail, they just break and that's it. I have had one jump time once, but that was just as bad as breaking.
__________________
Nic 1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed |
#3 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
IMO, pulling the timing cover is not that big a deal....compared to if the timing belt breaks. Wouldn't take you long. Shouldn't be more than an hour job. Pull the plug wires, the belts, the radiator hose, water inlet pipe and studs, cover bolts, and then the cover. Look for cracks, fraying, tension, etc. Inspecting the top idler pulley/inlet would be good too with that many miles on it. The bearings should rotate smoothly with no play.That's what I would do, anyway.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#4 (permalink) |
Has it ever been changed? If not I'd start considering replacing it and the water pump. Might as well do one if you're doing the other...
__________________
-1992 4Runner (Medallist Edition) Still given 'er 16 years later -Santa Cruz Bullit -Giant STP1 -Empty Wallet Adam |
#5 (permalink) |
The warning is the valves hitting the pistons.
#6 (permalink) | |
ouch...hehe
__________________
#7 (permalink) |
Not in a 3vze...
__________________
#8 (permalink) |
3vze is a non interference motor so when the belt breaks it just stops running nothing gets hurt, except your wallet from the tow home.
#9 (permalink) |
Just replaced mine at 215k it was working fine but it didn't look the best.
__________________
http://ps3mods.blogspot.com - http://kenvsryu.blogspot.com 1992 X-Cab V6 5sp Manual 215k SR5 :D runnin 31x10.5 17.8mpg :) |
#10 (permalink) | ||
Quote:
Still...ouch. (It would still be a PITA)
__________________
#11 (permalink) |
Yeah and no. Getting stranded sucks, but doing preventative maintenance ain't so bad. It's really not that hard of a job. You can do it on a weekend with a day to spare, depending on your skill level.
__________________
#12 (permalink) |
Thanks...I will take the cover off and check it...appreciate all the response.
#13 (permalink) |
well I know when mine broke I had extremely horribly performance prior, a few teeth had broken off and done somthing to the timing.
Mine finally broke when I tried to start it after I got home.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#14 (permalink) |
I had never dove into an engine until i did my timing belt, water pump and thermostat. Then the next time in I reshimmed my valve train. The thrid time in I fixed the blown HG....and Im sure I can do a timing belt very quickly now.
Just take it slow, follow your FSM to the letter and if you have any doubts take 80 billion pictures! and label stuff as you pull it off of the engine.Think of it as a stepping stone...
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 |
#15 (permalink) |
Hah, word of advice: when putting the new belt on, the arrows on the cam gears both point UP... My dad and I screwed that one up. The pass side was up, but the drivers side was down. Luckily we fired it up for a second to see if it was right. There's something about a 4runner running on 3 cylinders.... It did fire though, but god was it ever terribly rough!
![]() So yeah, take it slow, read the instructions... That's probably the dumbest thing I've done when working on a vehicle...
__________________
#16 (permalink) | |
Quote:
Timing belt life for the 3.0 is around 90,000km so if it has been done regularily then it will be due for a new one pretty soon. At the same time change out the water pump and spend the extra cash to change out the tensioner pully and the water jacket. I chose not to change out the water jacket and was putting a new belt and all new idler and water jacket less then 1 month later. The sound that the timing belt makes just before it is about to go depends on what is causing it. For me it was a squeeling bearing, followed by silence, followed by all the lights on my dash lighting up followed by the smell of burnt rubber and then a tow job. Then there is the 1-2 hours of extra work spent cleaning the belt remains and melted rubber off of every moving surface of each and every pully under the timing cover...There are 5 or 6 of these pullys to clean. Have fun!!! |
#17 (permalink) | |
my water pump is leaking so I'm going to replace my timing belt and oil pump while I'm in there. I'm also going to replace the belt tentioner and the idler pully. BUT WHAT THE
IS A WATER JACKET? thanks, thefreq
__________________
thefreqofnature Quote:
#18 (permalink) | |
The water jacket is just part of the water pump....the casing. Why do you ask?
__________________
#19 (permalink) |
huh?!
I thought that a water jacket is the sum whole of the cooling areas inside of the block containing coolant...hence "water jacket" You know that the water pump is just an impeller mounted on a chunk of metal that the timing belt turns right? Or do you mean that felt gasket that comes with the waterpump? Or do you mean that additional port from behind the thermostat housing for the oil cooler that only 3vz-e's with the towing package had? Or do you mean the thermostat?
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 Last edited by Bumpin' Yota; 04-23-2007 at 08:47 PM. |
#20 (permalink) |
90k MILES, not kilos.
Regardless, you're WAY overdue!
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#21 (permalink) | |
Read post #17...the guy says he's going to replace his water jacket. I'm relpacing my waterpump and timing belt and stuff and was looking for more info and other things to replace once I'm in there so I did a search and was reading that post where he says he's going to relpace the water jacket. I've always thought the cooling passages inside the block were called the water jacket. It didn't make sense to me so I thought I'd ask. thanks again
__________________
#22 (permalink) | |
Quote:
Water jacket is internal, the engine block and head castings. It is cored when the block and heads are cast. Not much to change.
__________________
99 4Runner, 3.4, 5 spd., Manually shifted E-Locker, 4:30 gears, 285/75/16 MTR's, Airbox mod through the bottom of the inner fender. |
#23 (permalink) |
ok good im not loosing my mind....despite what my coworkers may say!
__________________
#24 (permalink) | |
No, I'm the one losing my mind, I guess. Just ignore me. I had too much coffee today. I need to drink more water.
__________________
#25 (permalink) | |
Quote:
I'll tell ya the list is very very short
__________________
'95 PU Ext. cab, 4wd OEM 3.0L with spark delivered by OEM Ignition 348,xxx miles, on sixth set of tires sittin' on OEM wheels '04 Silver Corolla S, DVD head unit going in soon '85 F-250 351W H.O. 401,000 miles, first 351W dead at 367,xxx miles, Hedman headers, flowmaster exhaust, $1200 audio system, Alpine Alarm |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| It's Time To Give Her A Name | YotaFun | Off Topic Talk | 54 | 01-11-2007 10:25 AM |
| Noise present all the time except when I give it gas. | X13 | 86-95 Trucks & 4Runners | 5 | 03-26-2006 01:48 PM |
| Timing belt warning light how do you turn it off ? | beddo | Maintenance & Repair Archives | 17 | 11-07-2005 01:02 PM |
| Timing belt warning light ?? | 4 scotland | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 02-22-2004 10:28 PM |
