Does/did Suzuki use the same aisin locking hubs
Old 07-30-2008, 08:18 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
on thier samurai's, that are on our Toyotas? Or are the intrnals different? The face dial's look the same
Old 07-30-2008, 08:39 PM
Jay351's Avatar
Im gonna go ahead and guess the internals are a little different, along with the spline count....
Old 07-30-2008, 08:45 PM
ShredTheGnar's Avatar
Here's a quote from http://www.off-road.com/offroad/arti....jsp?id=399668 :
The Suzuki and 30-spline Toyota hubs are virtually identical except for the inner hub. The grips on the dial of the 30-spline Toyota hub stick out slightly beyond the cap, where on the others, it is flush. Functionally, the dials are interchangeable between the Suzuki and 26- and 30-spline Toyota hubs. The 26-spline (IFS) Toyota hub has a deeper backspacing between the mounting flange and the inner hub than the other hubs, in order to clear the spindle nuts. Because of this, the Suzuki or 30-spline Toyota hub body will not fit on an IFS toyota wheel hub, but the reverse should work; i.e. a 26-spline Toyota hub body should be usable on a Suzuki or 30-spline Toyota hub.
Good luck, just did mine yesterday.
Scott
Old 07-30-2008, 09:05 PM
Ok, so the 26 spline zuk won't work on my 91 add for conversion. Wasn't sure, guess that's why they're on ebay for less than $20, and the Toy's are over $70 on bid...thanks
Old 07-31-2008, 04:49 AM
Cyberman's Avatar
Ya, the bodies and the springs should be able to be used, but the rear spline and clutch will be different. I had a set of IFS hubs that were missing a spring, almost got one from a zuk.
Old 07-31-2008, 10:30 AM
Ahhhh, now I'm glad I didn't bid on them............thank you
G-off
12-29-2015 12:44 PM
Jason4X4
09-17-2015 08:02 AM
noahstancik
09-10-2015 10:47 AM
zz_denis
09-06-2015 03:43 PM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: Does/did Suzuki use the same aisin locking hubs
