Does Cold Air Intake Give Better Milege
Old 05-03-2008, 04:56 AM
simpsons721's Avatar
Red face Does Cold Air Intake Give Better Milege
Hey
do you get better milege with cold air intake
Thanks
Matt
Old 05-03-2008, 05:35 AM
X-AWDriver's Avatar
MPG gain is negligible but you might see 1mpg if your lucky.
Old 05-03-2008, 05:44 AM
YodaPala's Avatar
I got 2 w/ my airaid, then got 1 more with my spacer. I have a Jardine cat back also, She breathes well, every little bit helps.
Old 05-03-2008, 07:11 AM
Whitey13's Avatar
Originally Posted by simpsons721
Hey
Thanks
Matt
Nope.
Old 05-03-2008, 07:26 AM
MonsterMaxx's Avatar
It's possible, but doubtful, though breathing hot air on a hot day will rob you of power. I can feel the difference in mine. I did a design of a cold air system last time the motor was out, but didn't get around to making it yet.
Old 05-03-2008, 08:24 AM
iamsuperbleeder's Avatar
This is a very over-discussed topic on here. Personally, I didn't get a thing, only because now I just lay on the the throttle more because it sounds so cool. If I were to lay off the throttle more though, I may benefit from it.
I pieced together my own kit for about $60 instead of paying the outrageous price they usually are. And really with the way the tube runs, it's not a very "cold air" intake. The air heated from the radiator blows right onto it and heats the tube up bad. Now if you did the battery-intake swap, you might benefit a good bit.
Of coarse, this is on the 22re. I see by your sig you have the 3.0 in the Runner, I'd say just do the ISR mod and get a K&N.
Old 05-03-2008, 08:36 AM
Who did you get the tubing and connectors from?
Old 05-03-2008, 08:46 AM
eBay a while ago. Wish I could fine them again for my buddy's truck though. Paid about $20 for the tube, about $5 for the elbow, got the connector at AutoZone for the AFM for a few bucks (I was surprised it matched fairly well with the elbow), got an adapter of eBay for a few bucks, then got that crazy filter with the metal shroud on it from Advance Auto Parts (got 2 of them for a spare; they were discontinuing them, so instead of about $50 like it usually was, I got each for about $20).
Old 05-03-2008, 10:49 AM
Kiwipushrod's Avatar
Hey Guys,
An old hotrodders rule of thumb, with V8's, is; Every 10 degree F. drop in air intake temp, makes 1 more Horse power,.. so if "power is economy", then the answer to the question is, Yes.
Thanks, Kiwi
Old 05-03-2008, 10:53 AM
X-AWDriver's Avatar
How did the spacer give you mileage? There's nothing physical it can do on a direct port injection motor so this is really impossible. The exhaust is probably where you are seeing your MPG gain. What are you getting a tankful?
Old 05-03-2008, 11:20 AM
hmmwv15's Avatar
Super bleeder, can you mail/pm me the info on what you did for that set up? also the battery intake swap if you would. Thanks!
Old 05-03-2008, 12:08 PM
Green93's Avatar
Hey
Thanks
Matt
The 3VZE already has a cold air intake. If you take the lid off of the air box you will see a port from behind the headlight into the air box.
The intake is very restrictive though. I will be looking into doing the ISR mod myself for this reason. Look in the tech write-ups for ISR mod.
Jason
Old 05-03-2008, 12:51 PM
91Toyota's Avatar
Sweet! I'm thinking of doing a setup like this myself...since I have to buy a new air filter anyway and it costs like $25 for a STOCK filter
So, do you get like an intake noise when you give it a bunch of throttle? On my brothers 86 crx he gets a pretty cool intake noise...and thats what I am looking for. Thanks!
Old 05-03-2008, 02:24 PM
FredTJ's Avatar
Do you have any idea where the vehicle draws air from now ?
Fred
Old 05-03-2008, 03:28 PM
YodaPala's Avatar
Getting 300 a tank (20 mpg) I also have oversized tires with the 3:91 gears. Stock tires were 225/75/15 (28.3 inches) I have revo's now that are 255/70/16 (30.1 inches) I got thease tires b/c I did'nt want to mess with gears for now but maybe someday
As far as the spacer, I think its doin somethin I dont have to downshift as much thats all I know. Its got a Heili screw lookin inside that the air passes thru and it gets swirled I guess, it makes a "whistle" sound that sounds like a turbo spooling up. I like it, some people look at me when I'm goin by and they have a look on their face like....... what the?
Old 05-03-2008, 06:19 PM
FredTJ's Avatar
The spacer does absolutely nothing, other than make some noise.
Well, on second thought, it can/will increase your mileage.
When you buy the spacer you lighten your billfold weight, which in turn lightens the weight of the vehicle, thereby increasing mileage
Fred
Old 05-03-2008, 06:38 PM
Yeah, no problem man, but I'll have to wait till I get home on my own computer. I'm at my sister's house right now, but will be home tomorrow afternoon
Oh yeah, it's really loud after I put this filter on. With an open element, it still noticeable, but this one aplifies it even more like an intake resonator or something, lol
Old 05-03-2008, 08:49 PM
vermontoyota's Avatar
+1 super bleeder. you're gunna like the way it sounds and subesquently press on the skinny peddle a little harder and loose whatever you gain....
Old 05-03-2008, 09:32 PM
YodaPala's Avatar
Fred
Whadeva, proof is in the pudding. Have you tried one?
Old 05-03-2008, 10:13 PM
FredTJ's Avatar
Yup, we've tried 'em on several vehicles. No difference at all.
Enough people have tried them (with no good results) on several forums that I visit, for several types of vehicles.
By what magic do you think that they work, bearing in mind that I'm an engineer
Fred
Quick Reply: Does Cold Air Intake Give Better Milege
