Does code 24 affect the mass air flow sensor
Old 01-22-2013, 08:57 PM
rydholm11211's Avatar
I have an 1986 truck with a complete swap over of a 1989 enigne, the engine has great compression and everything, but will not idle, and when it trys to it just dies. But if I give it gas it will keep running, but it is reall hesitant! I checked the codes and it is telling me code 24 which states that is intake air temperature sensor. So I am assuming that the Mass air flow sensor has something to do with this, While I was looking at the wiring you can tell when the people before me had this truck they did some wiring with splicing around the connector to the Mass air flow sensor, But doesnt code 24 have to with the mass air flow sensor? Thanks.
Old 01-23-2013, 03:03 AM
TNRabbit's Avatar
First it's not a MAF, it's a Vane Air Flow Meter (VAFM). They work differently than a MAF.
Second, which engine/transmission are we talking about?
Third, the Intake Air Temp Sensor IS part of the VAFM assembly. Sounds lkke they might have FUBAR'd your VAFM.
Old 01-23-2013, 03:04 AM
Pat8942's Avatar
It's a Volume Airflow Meter not Mass Airflow Sensor.
Old 01-23-2013, 05:54 AM
mYnAmEiSmUd's Avatar
judging by the fact the truck was originally an 86, i think it is safe to assume that it is a 22re. Why anyone in their right mind would swap a 3.0 into a 2.4 bay is beyond me.
Now that the above posters have cleared up an confusion as to which particular part you are referring to.....
try pulling the EFI fuse (15 amp, lower left corner of the fuse box behind your drivers side kick panel). Leave it out for a couple minutes with ignition off. Plug back in and see if your problem still exists. You might get lucky.
If you are patient and handy with a multimeter, check out this link-> http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml.
If not, search your local craigslist, wrecking yards and if you must ebay for a maf... err i mean VAFM =D
Good luck man
Doug4320
03-24-2018 10:11 PM
RatOmeter
10-22-2015 03:17 PM
terminator
07-27-2015 07:13 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Does code 24 affect the mass air flow sensor
