Do your backup lights don't work?
Old 06-21-2007, 06:17 PM
Jay351's Avatar
If so check this out.
My backup lights have not worked since god nows when..
so today I finally drag my ass under the truck and look around for the reverse switch thing (2 prong switch that sticks out from the tranny)
on mine it was on the passenger side, very easily to see.
At first I could see that the plug was only halfway on, so I think "oh yeah, easy fix" so I plug it all the way in, put my key to the "on" possison and put her in reverse, go to the back of the truck.. nothing.
So okay, I crawl back under the truck and kinda think for a second.
I then realize that the switch can go on upside down and you cant tell the difference.
So I flip the wire around and plug it back in and what do I see when I go to the back end of the truck?
My reverse lights work!!
So if anyone has has tranny work and since then the reverse lights dont work, try this, its pretty easy to mess up the switch since it plugs in perfectly right side up or upside down, so the shop might have plugged it in upside down
Old 06-21-2007, 11:57 PM
91muddog's Avatar
mine NEVER apear to work.
i have to hold the brakes for light.
i asked my girlfriend to check for me while i was moving, she said they come on as soon as i start moving.
is this right?
i may look for said plug tomorrow or saturday morning befor ethe trip to sonoma!
YAY NASCAR!
Old 06-22-2007, 12:30 AM
Jay351's Avatar
My lights come on as soon as I shift into reverse.
Wether the truck is running or not (key in start position)
Old 06-22-2007, 01:54 AM
OSU4Runner's Avatar
Mine work, well I guess thats what you can call it......Now actually lighting up whats behind me........well thats the problem. Our reverse lights sucks....I just installed a set of 55w Hellas on the back of my roof rack, that took care of the problem. It also gets rid of tailgaters real quick at night!
Old 06-22-2007, 03:10 AM
Jay351's Avatar
I am doing the same thing
going to mount 2 offroad lights on my rear bumper (need to find a good spot) so
1. I can see whats behind me
2. a quick flash and no more tailgaters
Old 07-13-2007, 01:09 PM
stormin94's Avatar
Mine only work about half the time...they suck
Old 07-13-2007, 01:24 PM
1styota4X4's Avatar
mine are only working about half the time now as well and i have not been able to figure it out
Old 07-13-2007, 02:04 PM
Jay351's Avatar
check the plug wires..
Old 08-10-2007, 12:16 PM
fleurette's Avatar
I have the same problem, I checked the bulbs and they were fine. Is there a separate fuse for the backup lights ? Any pics showing the location of the plug you spoke of ?
Old 08-10-2007, 12:40 PM
crackerjack's Avatar
[QUOTE=Jay351;50557281]If so check this out.
If you're gonna use Gods name it should be with a capital letter. Unless it doesn't mean anything to you then Nevermind.
Old 08-10-2007, 01:05 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Excuse me, since when was this a religious forum? That's "offtopic" and an issue that could be taken elsewhere or kept to oneself.....instead of judging and getting all righteous...or something like that.
Old 08-10-2007, 01:33 PM
Jay351's Avatar
[QUOTE=crackerjack;50591289]
..... stop SPAMMING my thread.
Old 08-10-2007, 08:32 PM
fleurette's Avatar
I did my homework and realised that the fuse for the "reverse" is riding the same fuse as the turn signal. So if the flashers work, then the fuse is not the problem.
BTW, I checked for the plug near the transmission and only found a 4-prong that leaves the trans to go on the exhaust (a sensor/probe). That must not be the one ?
Old 08-10-2007, 09:02 PM
Jay351's Avatar
Im not sure if they changed it after 91 but on mine its on the passenger side close to the middle/top. (2 prong)
Old 08-10-2007, 09:20 PM
Kaleb's Avatar
I did the same thing with the same lights. Those lights work real well. Getting rid of tailgaters...works every time.
Old 08-11-2007, 08:59 PM
weaselman's Avatar
i just cut the wires before the plug and crimped and end on them and plugged them together...they work all the time now :-D
Old 08-12-2007, 05:59 PM
fleurette's Avatar
Would that be the "reverse" light connector that should be coming out of the tranny ? This one was found on the front, passenger-side.
Attached Thumbnails Do your backup lights don't work?-dsc00015b.jpg   Do your backup lights don't work?-dsc00016b.jpg
Old 08-12-2007, 06:57 PM
strykersd's Avatar
My reverse lights don't work because theres an electrical short somewhere. I need to get around to finding it some time.
gillesdetrail
11-19-2019 12:56 PM
Yota.Jay
03-06-2016 11:02 PM
aciorba23
06-29-2015 04:18 PM
ShaunKris
06-17-2015 04:33 PM
Land yacht
06-28-2002 09:53 AM
Quick Reply: Do your backup lights don't work?
