Do I need shackles?
Old 02-26-2012, 05:11 AM
Mashashin's Avatar
Do I need shackles?
I bought a set of sky jacker leaf springs from JCWhitney last night since it's free shipping on ANYTHING there until tomorrow night at 12. I figured 134 bucks for a brand new set shipped to my house would be a great deal plus I can get rid of the saggy springs on the truck. I mean one is literally parallel with the road with no weight in the bed and the other is slightly curved up still but not by much.
So, when I go to replace these springs should I replace the shackles as well or should I just redo the bushings and grease them before I install the springs?
Old 02-26-2012, 07:45 AM
rattlewagon's Avatar
Youll be fine with the stock shackles.
However, a longer shackle will add a little more lift, and might help the spring flex a little better.
Old 02-26-2012, 08:20 AM
jswizz's Avatar
Mashashin, I have an 85 was saged rearend 4runner and the 6" eye to eye equals like 1.5-2" lift , got rid of it . But since you just got suspension "for the rear"? I'm assuming you may not need it .How many inch lift are your springs? I also picked up a pair of skyjackers 3.5 and have yet to get all together for a ruff.
Old 02-26-2012, 09:15 AM
Mashashin's Avatar
My springs that I got were to eliminate the blocks in the back the P/O put on with the sky jacker lift kit. I'm going to transfer the AAL over to the new lift springs that will be here this week and it'll be about the same height as it was with the blocks in the back.
Old 02-26-2012, 09:30 AM
boxer.fan's Avatar
LOL at your avatar.
so the springs you are buying from JC are lift springs for that cheap, huh. I may have to take a look cuz my lift came with blocks and wish I had springs.
Old 02-26-2012, 09:31 AM
Mashashin's Avatar
I'm assuming their lift springs, if not I'm adding another leaf to compensate
Old 02-26-2012, 12:01 PM
mt_goat's Avatar
Post up a pic of your shackle angle after the new leaf springs are on. Sometimes going to a longer or different arched spring will require a longer shackle. The shackle has to be able to move rearward as the springs flatten out, more arch might need more movement than the stock shackle can handle. Or the other problem is the shackle can become inverted and lock forward in full droop situations.
Old 02-29-2012, 07:55 AM
yojohn3's Avatar
You should be fine with the shock one, but since your taking everything apart anyways y not replace them, also new u-bolts to, if your kit did not come with them just my opinion
Old 02-29-2012, 08:08 AM
MaK92-4RnR's Avatar
wont hurt to put a lift shackle on there... little more lift for when you load it down?
Old 03-02-2012, 11:14 AM
abecedarian's Avatar
One thing to consider is if the new leafs have camber shims included.
If the leafs have shims between the leaf and the axle, and then you add shackles for whatever reason, you may need to remove the leaf shims to prevent u-joint wear and vibrations.
Old 03-04-2012, 05:13 AM
Mashashin's Avatar
Well, this is fun... I get a call from the JCWhitney customer support line this morning "Mr. Gregory I regret to inform you that your skyjacker leaf springs have been discontinued and we as a company only carry one replacement spring for your vehicle not and that is a bellcheck 3' lowering spring for the 1991 toyota pickup 4x4."
WHAT?!?!?!! I flipped out at this guy, i apologized to him several times afterward but he understood, 134.xx shipped for a set of springs it outrageously low. Looks like I'm gonna have to spend 3.5x's that on a set of skyjacker soft-ride 4'' springs. Not looking forward to that nonsense. They will probably tell me that those springs are discontinued too.
I'm gonna order a set of longer shackles with these soft-rides since they are 4in. taller over stock.
Old 03-04-2012, 06:00 AM
jswizz's Avatar
Mashashan , that totally sucks I'da been pissed too ! after your initial post I lookked and was thinking of ordering some too . And what A Week later the guy tells you, dang . GOOD LUCK Id'e definatly go somewhere else.
Old 03-04-2012, 06:19 AM
Fossilized
Staff
dropzone's Avatar
Cool
3 foot lowering spring
Yep I know it is a typo
Old 03-04-2012, 06:55 AM
highonpottery's Avatar
What do you have now to give 6" lift with 31" tires??? Pics?
Do you need to be this high? OME leafs are around 300 a pair as an alternative
Old 03-04-2012, 07:04 AM
Mashashin's Avatar
It looks like an aal and 3in blocks. Not a fan of blocks at all
Old 03-04-2012, 08:07 AM
mt_goat's Avatar
Alcan custom springs is an great option, if you can afford it: http://www.alcanspring.com/
Old 03-04-2012, 12:43 PM
Mashashin's Avatar
i'm gonna remove the blocks when the springs i ordered today get here this week and that should put me about where I was with the block and aal I hope. If not I'll be slapping in the aal I have sitting around for the truck and just throw on 33's this fall.
Old 03-07-2012, 07:23 PM
Mashashin's Avatar
Got my springs in today. Funny though, I paid for UPS ground and they have all of the packing stuff from UPS but were delivered by Fedex. Also, it seems I'm just having the best of times trying to get these springs for my truck. The skyjacker 4in springs came in just fine but summit didn't send me my bushing kit I ordered too. I called them up and they called the warehouse and they had it sitting on their shipping dock from a couple days ago. That resulted in me getting them 2 day shipping for free and they're also sending me a detailing kit too ( wax, wash, shines, wipes, ect. ) A lot of good that does a truck that's 1/4 rhino lined, 1/4 rust, and 1/2 together
Old 03-07-2012, 07:56 PM
bob200587's Avatar
Is your avatar the dude's face shopped onto the baby and the baby's onto the guy?
Big Little Bear
230
11-13-2023 11:42 AM
Redeth005
06-28-2018 08:16 PM
Scottcrb
03-03-2016 11:57 AM
oldblue
09-28-2015 04:07 PM
sonorn67
09-19-2015 05:39 PM
Quick Reply: Do I need shackles?
