Do I need to mill my timing cover since my block was decked?
Old 12-04-2008, 04:54 PM
tim a.'s Avatar
Seems like I should,but I never have thought about it until I started putting it together.My shop took .07 off the deck so i guess they need to take that off the cover.Its a 22re by the way.Thanks for insight.
Old 12-04-2008, 05:55 PM
874runnersr5's Avatar
Yeah alot of people forget that, you should do it to the timing cover.
Old 12-04-2008, 06:00 PM
TOYOTA 1's Avatar
yea, the machine shop should have told you about that!
Old 12-04-2008, 08:39 PM
Pistonman's Avatar
Yes, you need to.
Old 12-04-2008, 09:11 PM
abecedarian's Avatar
it should've been bolted to the block when it was cut.
hope they can get it right without causing issues sealing with the head.
Old 12-05-2008, 01:25 PM
annoyingrob's Avatar
If they take too much off, you can just FIPG the top of it.
Old 12-05-2008, 03:26 PM
drew303's Avatar
Bolt it on and see if it's flush.
personally if its not flush I'd stick it on the belt sander. The top of the timing cover just needs to be flush. It's a not a pressure seal between the head and the cover, just an oil seal. It's just important it doesnt stick higher than the deck, because that could jeopardize the Head Gasket if the head is not on flush.
Having said all that, you may be able to manipulate the cover enough with the slack in the bolt holes to line it up flush. if your not comfortable with the bottom not being flush, that'd be a safer surface to grind down yourself since the pan uses FIPG or RTV vs the gasket used ontop.
just my .02
Old 12-05-2008, 03:47 PM
just my .02
the main issue with just manipulating it is the fact that the oil pump bolts to the cover and the drive gear is centered on the crankshaft, and then the front oil seal is centered to that. moving the timing cover down will affect clearances (read: bind the drive and driven gear) and have the front crank seal off-center.
.07" isn't much, but is a lot when dealing with gear mesh and seals.
and if that works, there's .07" protrusion by the timing cover into the oil pan sealing surface area.
TOYOTA 1's Avatar
just my .02
there are dowels in the block that wont let you, plus as abe said you dont want to use the slack in the bolt holes even if you could!
Old 12-05-2008, 03:48 PM
Originally Posted by TOYOTA 1
there are dowels in the block, so you cant use the slack in the bolt holes!
/me smacks self....
yeah that's an issue too.
bigjstang
08-25-2021 12:41 AM
Gamble_STi
07-07-2015 07:54 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Do I need to mill my timing cover since my block was decked?
