Do I need an adapter for 2-1/4" exhaust?
My plan is to replace my SUPER leaky factory exhaust with a custom bent "downpipe back" system. My only question is, do I need some sort of adapter for the 2.25" exhaust tubing? I was thinking I could use the factory cat flange and just weld the pipe to it, but will that work even if the pipe is bigger than factory?
Sorry if I don't make sense... Exhaust isn't my thing
yes you can weld to the original flange. if you need an adapter for it, the muffler shop can bend the end of the pipe with the pipe expander on the tubing bender machine to match the size.
a muffler shop can do what you need.
kawazx636
07-03-2023 03:03 AM
