Do I have my crankshaft pulley on right?
This is my 1st time tearing into a diffrent engine other then 22R, hell its the 1st vehicle I've owned with more then 4 cylinders.
I want to make sure I get everything back together right, I never took off the lower timing gear, just the Harmonic Balancer pulley so I could get the belt off. But my belt is fine so I just put it back. But by checking here is it all mounted up right?
Thank you!
Thank you!
looks about right. snap a pic of the front were the bolt goes (without the bolt in it) so you can see the sholder diff between the outside of the pully and the end of the crank
LOL Do I have to? I had to borrow a torque wrench that goes up to 180ft-lbs this morning to torque it down, and I already returned it.
If its consolation (spl) I could push my HB pulley pretty much that far in by hand, then just torqued the bolt on. I think its ok, I've double checked everything before I put it on. Just a little paranoid about that one thread.
charlie_fong
09-27-2015 10:06 PM
