diy dent removal
Old 12-27-2015, 02:27 PM
maroonyota's Avatar
Thumbs up diy dent removal
Best way to remove these dents? Its ok if paint chips or cracks bout to repaint, just seeing what ideas or shortcuts yall have used!Name:  20151227_170713_zpshtnzpdan.jpg
Size:  732.1 KB Name:  20151227_170730_zpsvrywf5nj.jpg
Old 12-28-2015, 07:27 AM
Lons81's Avatar
Buy or rent a stud welder and puller, would probably be the easiest to use
Old 12-29-2015, 12:25 AM
davehaynes1's Avatar
a stud welder would ruin your paint and maybe put little holes in your pannel...... but if you dont care about that and you simply want the dents out and dont want to rent one. a trick we used to use was drill a very small hole, screw some LONG screws in slights, clamp some mole clamps to the end and gently hit it out with a hammer.
not great but works a treat to get the big dents out
Old 12-29-2015, 04:06 AM
Obmi's Avatar
I have (Way in the past) putt a soccer ball between panels and inflated it. But that will depend on the strength of the back panel.
Eugene13
12-25-2015 02:51 PM
Zach_trun
12-23-2015 10:33 PM
Obmi
11-27-2015 03:13 AM
Brandon Dodson
11-15-2015 07:55 PM
mysteryfish
11-09-2015 01:11 PM
Quick Reply: diy dent removal
