Distributor, timing
Old 12-12-2012, 11:29 PM
Josh_Br's Avatar
Distributor, timing
I had been having idle issues, which I think are solved now by properly adjusting the TPS. When I was having idle problems, I loosened the nut that holds the distributor in place, and moved it. I would like to make sure I have it back in the right place. How can I do that? Thanks, Josh
Old 12-13-2012, 01:10 AM
LITLRED's Avatar
Need to know which motor you have.
Old 12-13-2012, 04:06 AM
vermontoyota's Avatar
You would need to jumper two ports in your diagnostic box (forget which ones) and then check timing with a timing light and adjusting distributor accordingly. Or just move it until it appears to be running smoothly and well.
Old 12-13-2012, 08:00 AM
Josh_Br's Avatar
Duh, sorry....22RE
Old 12-13-2012, 08:02 AM
Josh_Br's Avatar
Thanks, that's kind of what I did (move it until it runs good), but was wanting to get it more precise. Trying to get the idle as good as possible. Thanks for the info.
Old 12-13-2012, 08:22 AM
brianh699's Avatar
You short terminals te1 and e1 and you need a timing light to accurately set timing. If you don't have one check with your local auto parts store they probably rent one out.
Old 12-13-2012, 08:41 AM
Josh_Br's Avatar
Ok, thank you very much. Where are the terminals located?
Do you know the timing specs? I'm thinking it should be a -5 BTDC or somewhere around there.
Thanks
Old 12-13-2012, 09:49 AM
nctom's Avatar
On my '88 there is a fuse block in behind the battery (closer to the cab). The te1 and e1 are located in a little covered thingy just in behind the fuse block. Stick a paper clip in te1 and the other end in e1. Grab your timing light and point at the timing mark just above the crankshaft pulley. Look for the notch in the pulley - as you twist the distributor, you should see it move in relation to the timing marks. For the 22RE, set timing to -5 and you are good to go.
Old 12-13-2012, 01:55 PM
Staff
Terrys87's Avatar
Codes... http://4crawler.com/4x4/CheapTricks/...es/index.shtml
Video for installing distributor>>>> http://www.youtube.com/watch?v=9qEQM...ature=youtu.be
How to get Check Engine Codes and to set Timing. I just put this up for others. Applies to 87 and up. 86 and older is the bottom picture.
The Diagnostic port for the 85-86 is on the Drivers side inner fender and is nothing the same as the 87 and up. Here is T1 and E1 jumped. The codes and engine flashes are the same as the rest of the trucks on the dash.
Codes...http://4crawler.com/4x4/CheapTricks/...es/index.shtml
Old 12-13-2012, 02:53 PM
Josh_Br's Avatar
Wonderful, thank you! This has been a big help.
sandyota
02-04-2021 11:16 AM
msane99
07-11-2015 08:08 PM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: Distributor, timing
