distributor rotor at TDC?
Old 08-07-2011, 06:35 PM
geoduke's Avatar
I just got done replacing my timing belt and had my rotor way off to compensate in the meantime. After I opened it up, I saw that everything was off by two teeth.
In trying to put everything back together again, where should the rotor be pointing when the crankshaft is at 0 degrees TDC and the distributor marks are completely lines up (i'm assuming set to TDC). My rotor was either at 3 oclock or 9 oclock when looking at it from the drivers side of the vehicle.
I assume I should point it to the marks on the distributor (where the #1 plug wire goes) but 90 degrees seems like a crazy adjustment from where it was before.
Help me get this thing firing tonight! Thanks.
Old 08-07-2011, 06:42 PM
ebrake92's Avatar
More towered 11ish was where mine was but obviously 9 is the ticket
Old 08-07-2011, 07:50 PM
geoduke's Avatar
Alright yeah, that makes sense. I just looked at what the cap looks like. I cranked it and it made a god awful noise. I don't even know where to begin now.
Old 08-07-2011, 08:03 PM
4x4climber's Avatar
make sure it is at cylinder one TDC. Point it toward the number 1 cylinder (rotor) about 10-11 o clock. Start it off retarded and move into advance... Don't try n start it up fully advanced. Make sure it is jumpered. Good luck
JonG85
01-18-2023 04:31 PM
ladybugRC
458
08-21-2020 10:41 AM
LittleUgly
15
01-02-2020 01:30 PM
Kamaloha
10-16-2015 05:13 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: distributor rotor at TDC?
