Distributor pinch-bolt
Hello. This is my first post on this forum. I went through quite a few old threads to find an answer to my simple question, but I think it’s probably just too simple for someone to describe.
I own a 22RE. I just moved from OR to CA and failed the emissions test because my timing was very slightly off. With the TE1 and E1 jumped, rpm reading 850, timing is 3 degrees where it should read 5. All I need to do is rotate the distributor for the adjustment, the only problem is I do not know which bolt is the pinch-bolt.
Can someone please describe (or show in a pic) where the pinch-bolt is?
Thank you!
Thank you!
LittleUgly
15
01-02-2020 01:30 PM
Sam hain
19
09-30-2015 08:25 AM
EatChipsNow
09-09-2015 01:25 AM
