Disabling factory alarm on 1990 4runner? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-12-2006, 01:02 PM   #1 (permalink)
Update 9/15/2007. I'm about to go insane. I hate this freaking alarm. I was able to bypass it in valet mode for the last year and today I am selling the truck. I unhooked the battery to remove my stereo and then this morning the alarm was going off for no reason. I do NOT have the REMOTE. I waited until it quit going off and it started and I pulled it into the driveway. It went off again and I disco'd the battery to get it to stop. I now went to start it and the STARTER IS DISABLED. I CANNOT SELL MY TRUCK BECUASE THE FREAKING ALARM IS STUCK ON.
Is there ANY way to disable this alarm? Please help this is urgent .....
Justin311 is offline
Old 04-12-2006, 08:05 PM   #2 (permalink)
Nobody? I removed the switch pod and thought it was fixed. About an hour later however the alarm went off. Anybody cured this yet?
Old 04-13-2006, 03:10 PM   #3 (permalink)
Anybody have the factory service manual and could look up the factory alarm wiring for me?
Old 04-13-2006, 03:17 PM   #4 (permalink)
Flamedx4's Avatar
To the best of my knowledge there was no factory alarm or keyless entry as far back as as 1990, and there is no mention of either one in my 1990 FSM.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 04-13-2006, 03:36 PM   #5 (permalink)
celica's Avatar
What makes you think it is factory?
__________________
Matt
2003 4-Runner Limited - Couldn't stay away from the runner
2003 Sequoia Limited
1989 Supra Turbo
1992 4r, 5spd V6 Sold
celica is offline
Old 04-13-2006, 03:38 PM   #6 (permalink)
celica's Avatar
Flamed - what the heck is is the back of a CJ doing in your avatar - no no no
__________________
Matt
1989 Supra Turbo
celica is offline
Old 04-13-2006, 04:51 PM   #7 (permalink)
littlerunner's Avatar
it could be factory,my 91 runner HAD a factory,very easy to undo,remove center panel under radio cluster just in fron of console,ck under dash & at ignition cylinder,behind cover at B pillars,if it is factory there should be connectors at those locations with Y connectors that can be disconnected & then the harness on the car connected back together,cant remember if any behind glove box,hope this helps
__________________
91 4runner,5spd,bone stock,rblt 3.0 @ 303,000 miles.OME 900 rear springs,front & rear shocks.97 runner wifeys
littlerunner is offline
Old 04-13-2006, 04:52 PM   #8 (permalink)
sorry i said factory,could be "port installed also"---added after in states
__________________
Old 04-13-2006, 08:07 PM   #9 (permalink)
It looks 100% factory and honks the factory horn, wiring harness is OEM toyota....I sincerely doubt it is aftermarket, I'll snap some pics.
I'll pull the plastic at those spots you metnioend and see if I can find any "Y" connections, so far I can only find straight harnesses.
Unfortunately I guess I will have to completely unwire it, I was hoping to pull a fuse, discon one harness, jump a wire, etc, so that if I wanted to hook it back up (going out of town, parking in bad neighborhood, whatever) I could. Oh well, guess I'll spend the money on a new alarm if I want to do that.
Old 04-14-2006, 07:00 AM   #10 (permalink)
celica's Avatar
if it is factory I would think that toyota would make it plug & play. Aftermarket installers are the ones that slice & dice
__________________
Matt
1989 Supra Turbo
celica is offline
Old 04-14-2006, 08:33 AM   #11 (permalink)
Quote:
Originally Posted by Justin311
The 1990 self-arming factory alarm is driving me nuts, and my key fob doesn't always work. It has three positions - "honk defeat", "center" (not labeled) and "valet" (never gotten that one to work).
I have the same system on mine. The manual is separate from the owner's manual.
To put the alarm system into valet mode: position the ignition key at ACC then press the button until the LED turns solid red. Your system is on valet mode: system does not auto arm and in fact, it's not even active. However, the led will still flashes to give an impression of an active alarm system.
Also you mentioned about your fob functioning intermittently. I bought a replacement fob here: link
__________________
'93 4Runner SR5
edikp is offline
Old 04-14-2006, 11:52 AM   #12 (permalink)
Bobakazi's Avatar
Send a message via AIM to Bobakazi
Agreed. Your valet setting is the key for making it not arm itself. You can always turn the valet off later to make the alarm function again. In the center position, when the alarm goes off, does it siren and honk?
__________________
'90 Extra cab V6 4x4 PU
5.29 gears. Detroit locker front, Detroit Truetrac rear.
35" BFG mudders. Trailmaster 4" susp, 3" body lifts. Add-a-leaf. K+N intake, 2.5" exhaust with Flowmaster 40 and a cat I got off an Evo VIII.
Bobakazi is offline
Old 04-14-2006, 09:25 PM   #13 (permalink)
Dude, you are my HERO! I don't have the manual so I didn't know you had to put the key in ACC to get valet to work. I would push the valet button but it wouldn't seem to work, so I thought that setting was broken. You have made my life SOOO much quieter LOL
Old 04-14-2006, 09:26 PM   #14 (permalink)
Quote:
Originally Posted by Bobakazi
AIn the center position, when the alarm goes off, does it siren and honk?
Yes, it gos off in the center position, but there is no siren in any setting. Only an annoying honking!! The "honk" setting is only for when arming/disarming. One honk = armed, two honks = disarmed. If you put it in the "honk defeat" it just flashes the lights to let you know. Kinda like a "silent arm" on today's systems.
Old 04-20-2006, 11:25 AM   #15 (permalink)
Glad I could help.
__________________
'93 4Runner SR5
edikp is offline
Old 07-03-2007, 02:28 PM   #16 (permalink)
Injohneer's Avatar
So which remote did you go with, and does it work well for you?
Do you wish you'd gone with the other one that cost much less (or much more, depending...)... it looks like the bottom one has more buttons = more features?
One-button for $44
for $54
Two-button for $84
My alarm just decided to start working the other day while I was at lunch... I saw someone with a 3rd gen leave the parking lot, so I bet they armed my system when they disarmed theirs! It sure would be nice to actually control and use mine...
__________________
Trail/Build Rig: 1981 Toyota Pickup 4x4, flatbed
Tow Rig: 2001 Chevy 2500HD Duramax 4x4, X-cab Long Bed. Will be my tow rig, when I get a trailer.
RIP: 1995 4Runner.
Injohneer is offline
Old 07-03-2007, 05:14 PM   #17 (permalink)
Per what the website suggested, I went with the first one on list (the $44 one). You may want to contact the site/seller first to make sure.
Not sure about more feature capable if you were to use the one on the bottom (the $84 one). I think the factory one has only three features: lock, unlock, and panic.
__________________
'93 4Runner SR5
edikp is offline
Old 09-15-2007, 09:13 AM   #18 (permalink)
Tags
4runner, 91, alarm, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1994 4Runner Factory Alarm zbadboy69 Alarm Systems 0 03-12-2007 08:59 PM
Stock Alarm question (disabling) cackalak han 95.5-2004 Tacomas & 96-2002 4Runners 9 09-22-2006 12:12 PM
95 4runner factory alarm 1styota4X4 Alarm Systems 4 05-26-2006 04:22 PM
Did the 97 4runner have a factory alarm ? pfbmgd 95.5-2004 Tacomas & 96-2002 4Runners 4 12-05-2003 04:54 AM
Alarm Disabling DSP 95.5-2004 Tacomas & 96-2002 4Runners 5 04-19-2003 11:25 AM
2009 InternetBrands, Inc.
