Dirt bike carrier springs/shocks help
Old 06-18-2008, 04:54 PM
Duartizzle's Avatar
Hey i just purchased a dual dirtbike carrier that attaches onto the hitch. I put it on with 2 bikes and my 93 runner was tilted very far back. the carrier itself had at most 3 inches of ground clearance. I need to upgrade the springs and shocks to alleviate this problem. I don't know what combination can provide what I am looking for. Basically, I want very very minimal dampening when any amount of weight is either in the runner, or coming from the hitch. Just as an FYI the bikes with the carrier are in total of close to 600 pounds
Old 06-18-2008, 05:00 PM
crolison's Avatar
heavy duty old man emu springs or some rear fj80 coils
Old 06-18-2008, 05:21 PM
abecedarian's Avatar
airbags?
Old 06-18-2008, 05:24 PM
Duartizzle's Avatar
would the heavy duty old man emu really make it so there is minimal dampening? and would it work on a 4x2?
Old 06-19-2008, 07:57 AM
Duartizzle's Avatar
bump, anyone else?
Old 06-19-2008, 02:05 PM
Matt16's Avatar
Landcruiser coils or HD OME coils, your truck will handle weird with that much weight on the hitch (500lbs???).
Old 06-19-2008, 02:47 PM
Duartizzle's Avatar
hm, i never really thought about the handling being an issue
Old 06-19-2008, 03:25 PM
just a 22re's Avatar
thats alot of but weight there man you should take one and see if it fits inside the rear cargo first
Old 06-19-2008, 03:30 PM
Jay351's Avatar
Airbags! They will help the load and will be pretty much unnoticable unloaded.
Old 06-19-2008, 03:57 PM
Matt16's Avatar
With 500lbs on the hitch, your front end will be levered up which will change your alignment a bit. I think that is probably too much for the vehicle. You could get airbags to solve the problem.
Old 06-19-2008, 04:33 PM
Duartizzle's Avatar
I found these, would these alleviate my problem: http://www.suspensionconnection.com/...con/4112T.html
Could I rely entirely on those airbags alone, or would I still need this entire kit? http://www.trdparts4u.com/PD-4RUNNER....aspx?MakeID=1
Old 06-19-2008, 06:38 PM
Jay351's Avatar
You could rely on the bags themselves if they are of decent quality. The ones you posted look okay.
Old 06-19-2008, 06:59 PM
Whitey13's Avatar
What the hell are you talking about?
Old 06-19-2008, 07:02 PM
Whitey13's Avatar
Are you running a class 3 hitch? If that's the case, you are definitely exceeding the hitches tongue weight. I'd look into it before you do any upgrades.
Redeth005
06-28-2018 08:16 PM
live4soccer7
05-11-2016 06:52 PM
83yotastockR
11
11-10-2015 06:54 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Dirt bike carrier springs/shocks help
