is this differential normal? (pic)
When checking the diff, the ring (big) gear should spin smoothly with a little resistance. When you rock the ring back and forth, it will make a tiny "clack" when changing directions, you should barely be able to see the play that accounted for that noise as its should be about 0.01" for a used diff. Make sure the faces of the gear teeth are smooth as well.
jerusry
10-19-2015 05:28 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
ripp96
07-31-2015 11:14 AM
ripp96
07-25-2015 02:32 PM
