Differences between 85 and 87 22re?
Old 11-04-2010, 08:14 PM
twistedyota's Avatar
Exclamation Differences between 85 and 87 22re?
i have a 87 4runner with a warped block, i may be getting a wreced 85 pickup and i was told tht their might be differences between the 2 engines.
I found some differances from another engine i had but i do not know if it was just mainly because it was a 22r or because it was and 85.
any help would be greatly appreciated.
Old 11-05-2010, 12:55 AM
myyota's Avatar
You will need to swap all the sensors and the injectors over to the new engine, otherwise its mostly the same.
Old 11-05-2010, 06:30 AM
xxxtreme22r's Avatar
all 85-95 engines were the same except for the way each one was controlled. WHen comparing a 22r to a 22R and a 22RE to a 22RE. ie different sensors, different ecu's etc etc. As long as you keep the old sensors from the old motor and transfer them to the new motor you should not have any problems.
Now where you will get into issues is if your going to/from an 85-95 22RE and 85-95 22R.
Converting an RE to a carburated R is a little easier than swapping in an RE into an R truck. This mainly because of the differences in the wiring harnesses.
You are pretty vague in what your asking here and not sure if the 85 engine your getting from the wrecked truck is a 22r or 22re. I know your sig says your 87 has the 22re in it.
Old 11-05-2010, 06:58 AM
waskillywabbit's Avatar
Yep. Might do a tune up while the motor is out as well and perhaps a timing chain, water pump tstat.
:wabbit2:
Old 11-05-2010, 07:00 AM
Kiroshu's Avatar
Mostly emissons differences. And wiring harnesses.
Old 11-07-2010, 01:09 PM
i am puttin my new timing chain on it.
Old 11-07-2010, 01:13 PM
the wrecked truck is a 22re and i was wondering if their was any differances between the 1985 22re and the 1987 22re
Old 11-07-2010, 01:15 PM
4runnerx3's Avatar
The deck height on the block is different. So the timing covers are different.
Old 11-07-2010, 01:17 PM
thank you. is their any other differances you know of?
Old 11-07-2010, 01:18 PM
wrong. 81-84 had the different deck heights.
Old 11-07-2010, 01:22 PM
so my timing chain for my 87 should work?
Old 11-07-2010, 01:26 PM
yes all the timing chains etc from 85-95 were all the same. 81-82 were dual row with the taller deck height, 83-84 were the same deck height as the 81-82 but only had a single row.
Old 11-07-2010, 01:28 PM
ok thank you
Old 11-07-2010, 02:11 PM
4runnerx3's Avatar
I thought the early 85's were taller.
Old 11-07-2010, 02:21 PM
no, you can easily tell when ordering anything timing related or heads. They all say 85-95.
Old 11-08-2010, 08:19 PM
Originally Posted by razed
you can look at the exhaust side of the block and if they look like this
they're the same
but some 84 engines did make it into 85's
thts very help full i. i had a 22r tht came out of a 1985 truck tht had the taller head which confused me.
yup. i just looked at the pictures of the 22r engine i have and it doesnt have the id
Old 11-09-2010, 11:56 AM
and you said 22r? you'd also have to swap the fuel pump block off plate from your 87 onto the early engine- it's on the front, intake side of the head.
forget the last part.
what happened is i bought a 1985 22r but i am now getting a 1985 22re this weekend.
edit: srry i hit the T instead of the W. fixed.
shisha1999
09-21-2015 08:22 PM
deepmarsh
08-06-2015 03:44 AM
boogiewoogie
07-24-2015 05:10 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Differences between 85 and 87 22re?
