| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Difference between a cracked head and a blown HG
#2 (permalink) |
There isn't a good way to tell a cracked head from a HG issue without pulling the head. Cracks can be so small, they're almost impossible to see, even if you know where you're looking... That's why shops pressure test.
Vehicles with blown HGs can run fine... Best way to see how bad it is w/o disassembly is a leak down test..
__________________
http://www.22REturbo.net |
#3 (permalink) |
for that price i would buy it regardless of the reason
#4 (permalink) |
I do not know I am sure someone will chime in. But a HG can be replaced and the heads machined down. A cracked head you would need a new head for the engine.you will not intil you take of the head though.
#5 (permalink) |
Ya, the body looks pretty good. 212k miles. i found a new head on ebay for $300. Is that a reasonable price? It didn't have any of the valves or anyhting in it but the cracked head would have all of that. I could have it all swapped over.
#6 (permalink) |
Heads are cheap. If that is all that is wrong with it, go for it. Go with a head from engnbldr.
Forgot to mention that you can pull the head and have it inspected for cracks, milled, etc, but that will most likely be over $100 right there so you could just put that towards a new one. The only downside to a new head is it can cause your bottom end to go out from the new increase in compression. Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s Last edited by rdlsz24; 04-05-2007 at 12:56 PM. |
#7 (permalink) |
Well, if I buy it, pull the heads and find out that the HG was blown, then there doesn't seem to be any reason to buy a new head. I'd just get the one I pulled cleaned up, milled and the valves reground. It seems super unlikely that the head would crack AND the HG would blow.
#8 (permalink) | |
Quote:
I guess it all depends on how long it was driven with a bad head gaskets. If it lost all it's coolant and overheated, you can bet the head is toast. If the previous owner killed the engine and towed it home as soon as they saw smoke, it may be ok. In this kind of deal, plan for the worst (full engine rebuild) and hope for the best (head gasket).
__________________
Daily: 1990 2nd Gen 4-Runner SR5 V6 Toy: 1988 1st Gen 4-Runner SR5 V6 |
#9 (permalink) |
what year runner are we talking about, and what engine?
#10 (permalink) | ||
Quote:
the HG can fail w/o a cracked head, it may warp if overheated though. the heads comin off, so have it checked before you buy a new one.
__________________
sarcasm noted...and appreciated im with the banned Quote:
#11 (permalink) |
Once the heads are removed, have them pressure tested and resurfaced. There is no way to be certain while the engine is together. A good machinist might be able to weld it if it does have a crack
#12 (permalink) |
I paid 900 for a 95 4Runner that is beautiful and had a blown HG -- so I would agree that it sounds like a good deal. Always plan for the worst - If your counting pennies it might not be the best project, but if you have the money, tools, and time it is a good project. And i have lots of extra parts you will need
![]() I would pop the oil drain plug and see what comes out. If it's a HG, you should get coolant coming out before oil. The toyota dealer pulled the oil filter for inspection to figure out there was a HG failure on mine as well... Not exactly sure what they looked at thou. Kat
__________________
95 4runner 2wd 3.0 v6 Downey headers (dont buy them) Downey 2 1/2" full exhaust/Carsound cat Weasy2k cams/ENGNBLDR's o/s valves ported and polished heads/intake New project- 94 4runner V6 4x4 A/T 3" 4Crawler BL on order 33x12.5 BFG A/T's on 15x8 Cragar Black Steel Wheels 90 4runner 4x4 3vze Auto parting out - let me know if you need anything! 85 4runner, SFA, 22re, 5speed parting out |
#13 (permalink) |
I would be careful replacing a completely rebuilt head on a block with high miles... you may end up stressing the bottom end too much... just a thought, may be a good idea to rebuild the bottom end while you're at it and have a new motor...
__________________
'94 Single Cab 4x4 Pickup Turbocharged/Modified 22RE SDS EFI System Std 5spd 31x10.50 BFG's |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| hg blown | onion_75 | 86-95 Trucks & 4Runners | 23 | 06-08-2007 09:40 AM |
| Is my HG blown or not? | hektikwon | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 07-29-2005 11:05 PM |
| Cracked Head or Blown Head Gasket? | StevenR | Maintenance & Repair Archives | 5 | 06-14-2005 10:49 AM |
| Blown Head Gasket Blown! '95 3.0...Looking for advice... | bgibb | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 06-12-2005 02:52 PM |
| HG Blown need some info | DubJunkE | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-31-2004 09:01 AM |
