diff leakin - what do I need to fix this?
If it is leaking around the mating surface, one option is to snug up the nuts on the studs. Take care you don't snap them off, I think they only take around 19 ft.lb. torque on those. If that does not do it, you'll need to pull the 3rd member out then clean the mating surface and apply some sealant and reinstall the 3rd.
If its leaking from where the 3rd bolts to the axle housing you need a new gasket, so you will have to pull the third and axle shafts to get at it.
I have to do mine
I have to do mine
give us a pic from the front of the 3rd where the d-shaft attaches to the pinion flange. Mine is leaving drips like that do to a bad pinion seal, but hard to tell from the back picture.
i believe that is called the companion seal and i have heard they are fairly easy to change.
Oh, fill plug gasket. That's super easy to fix. Was that a gag saving that pic till last? Just to see if people might guess that?
polo451
13
11-20-2016 07:49 PM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
Steven.m.paulk
07-24-2015 01:44 PM
scottyg486
07-19-2015 05:34 PM
