Diesel conversion underway - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-24-2006, 05:18 PM   #1 (permalink)
Ok, another diesel conversion is now underway. I will try and keep everyone updated as it progresses. My half-cut arrives next week and so now the painstaking task of disassembling the 3vze is now underway. The first two pictures are the donor factory diesel engine/transmission from Japan. The second is the truck it's going into. Factory toyota diesel baby!!!
Dieselyota is offline
Old 01-24-2006, 05:20 PM   #2 (permalink)
new truck
Heres a pic of the truck that the diesel is going into. It's a v6 ext cab auto sr5 w/ power everything.Supposedly, after the swap I should be seeing high 20's in the mpg dept and I can finally use bio-diesel...
Old 01-24-2006, 09:23 PM   #3 (permalink)
colsoncj's Avatar
Send a message via AIM to colsoncj
AWESOME! what model is the diesel and tranny your using?
__________________
Cory
Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here
04 Dodge 2500 Cummins - DD/Tow Rig
02 Z06 Corvette - Weekender
94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727
72 Buick GS - i.e. the project that will never get done.
colsoncj is offline
Old 01-25-2006, 12:03 AM   #4 (permalink)
breknraj's Avatar
Question
If you don't mind my asking, how did you go about sourcing the engine (half cut), and how much did it cost? I'm entertaining just about anything, right now, since I currently have a full size 3VZ-E paperweight.
I'm leaning toward the 3.4 swap, but I could certainly see some advantages to having a diesel under the hood, as well.
Thanks for any info!
breknraj is offline
Old 01-25-2006, 08:51 AM   #5 (permalink)
I am using what's called a 1KZ-TE engine. It's a 4 cylinder turbochared diesel engine. Completely computerized and it makes about 150hp and 220ft/lbs torque. The cost is about $4000 delivered but I'll also be getting about 25-30 mpg. The unit comes complete with transmission and all wiring etc. Basically the entire car from the shifters forward. You can get a chip for these engines out of australia to bump up the power to about 200 hp and 300 ft/lbs torque. From those I've talked to that have driven them, this engine will keep you pushed into your seat until the o/d kicks in. Here's a link to my engine running before it was cut in half.
http://www.jarcoinc.com/video/061205/KZN130-9055245.wmv
Old 01-25-2006, 09:13 AM   #6 (permalink)
For that price what is the milage on that thing and did it come with the ECU and harness?
__________________
89 v6 SWB truck *PROJECT "BLACK BEAUTY*
P&P heads, EB's OS SS valves,30 over on the bottom and deckedto zero, taurus fan mod.
suprathepeg is offline
Old 01-25-2006, 05:00 PM   #7 (permalink)
Staff
aviator's Avatar
I love it! Couple of quick questions for you...
Can the engine be sourced with a manual tranny?
did you get the fenders with the clip? if so are you going to use them? if not I would like to talk to you about the factory side marker lights/harness.
can't wait to hear more about this conversion. Cheers aviator
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club - Get well soon Mary
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Old 01-25-2006, 11:43 PM   #8 (permalink)
Praufet's Avatar
Send a message via AIM to Praufet
one thing I've always wondered about that engines is parts. What do you plan to do if something breaks?
__________________
--Brian
'94 4Runner SR5 4WD
285 Terra Grapplers on FJ80 wheels|Rancho 9000s on all 4 corners|Cruiser coils|Marlin Rear brake line
Stereo
CDT Audio CL-61A|CDT Audio CL-6X|Profile 640 and Profile 600M|Audiobahn 100Q
Praufet is offline
Old 01-26-2006, 08:38 AM   #9 (permalink)
Yes, manual transmissions are available although more expensive. The only difference in those and the w56 is the bellhousing (which is interchangeable). Parts availability is not a problem currently. Anything you need, you'll have to order of course. But ordering parts from australia is actually faster than getting them from the USA since everything has to be airmailed. I ordered some parts from a previous conversion and it turned out to be pretty cheap to ship from Melbourne. The clip came as if you walked out into your driveway and cut your truck in half behind the shifters, took the front wheels off and shipped it. The clip starts in the cut state and the a/c even works! Ecu,wiring, radiator,fuel filter/heater everything, even a right-hand drive dash with ash tray We perform the swaps for others on an individual quote basis. Our shop that we work out of is located in Austin, Tx. The most commonly swapped truck is the 89-95 toyota 4x4. Earlier body styles are the same just more expensive to have us do since some creative thinking comes into play when it comes time to wire everything up. Everything is bolt-on on the 89-95 trucks and the wiring is limited to extending the instrument cluster wiring so that it will reach to the left side of the vehicle. As far as mileage, Ithe clip I got has 112,000 kilometers which is around 70,000 miles? You'll be seeing about 25-30 mpg consistently.Oh, there is a less powerful engine available in the half cut for as well for $2400 plus freight. It's not a bad engine and will give approx the same mpg. -Todd
Old 01-26-2006, 12:00 PM   #10 (permalink)
Praufet's Avatar
Two questions.
1. If you buy the half cut, is that all you need? Assuming you have a v6 currently.
2. How much is that chip you were talking about?
Also it may be faster to get parts airmailed here than shipped in the us, but its still not quicker than being able to run down to the local auto parts store
__________________
--Brian
'94 4Runner SR5 4WD
Stereo
Praufet is offline
Old 01-26-2006, 02:10 PM   #11 (permalink)
After numerous trips to the local auto parts stores with crappy or mismatched parts, I gave up going to them for anything other than oil etc. The accessories are all stocked by us parts dealers.
Old 01-28-2006, 03:28 PM   #12 (permalink)
gwhayduke's Avatar
Glad to see you're doing another diesel. I know you're in Tejas, is your source for diesels located here also or do you locate your own then import them? Been wondering about the feasibility of bringing a 1kzt up from Central America.
__________________
'99 4Runner SR5 4WD, 5-SPEED. Abzug's vehicle for urban expeditions, navigating flash floods and debris flows (try 12-15 inches of rain in one week). It always gets her home.
'95 4Runner LIMITED 4WD, 5-SPEED, over a quarter million on the original 3vze & headgaskets. TRD heavy duty clutch, TRD heavy duty flywheel, OME 900 springs and shocks. This old gal has gotten me out into the field, and back for 8 years, never failed to start or gotten stuck.
gwhayduke is offline
Old 01-29-2006, 10:47 AM   #13 (permalink)
Send a message via AIM to blackrunner91
Is it harder to swap the 4cyl turbo diesel into an original 22re '91 model than the v6 models? Also, like Praufet said, is the half-cut all you need?
__________________
'91 4Runner 22RE 4x4 project rock crawler...on hold
'93 4Runner daily driver...1uz Lexus v8 swap. Next up, D44 swap
blackrunner91 is offline
Old 01-29-2006, 01:05 PM   #14 (permalink)
gwhayduke's Avatar
By all the reports I've read, the 2LII T and TE drops right in, uses the same mounts and bolts right up to the tranny.
__________________
Old 01-29-2006, 05:54 PM   #15 (permalink)
photomike72's Avatar
I'm in Texas. Whats the turn key price on a swap in a 94 4Runner? ballpark of course......
I like to plan ahead.
Mike
__________________
1994 4Runner SR5 V6, 2nd HG, Downey headers and custom crossover, Aisin manual hubs, full OME suspension, Optima Red Top, Carsound hi-flow cat, Magnaflow with 2 1/4" pipe, K&N drop-in, Yakima rack, F/R diff breathers, BF Goodrich A/T's, ARB Bull Bar, "Highway Blaster" horns, more to come......
photomike72 is offline
Old 01-29-2006, 06:25 PM   #16 (permalink)
There is not alot more to do on the v6 vs the 22re other than torching the engine mounts off the frame and swapping in the diesel mounts. Turnkey this is probably in the neighborhood of $5,500 for us to do it for you. The big bear is the wiring, which when we are finished will all be factory. Consider this option when a new 3vze installed is around $4000 from a reputable shop. You will essentially double your mileage and you'll have great power output at low range (perfect for rock crawling or a hunting rig). The 3vze is a POS and should be used for nothing other than a boat anchor. Anyone who drives a modern computerized toyota diesel is hooked from that point on. They are ultra quiet, smooth and have excellent economy. This is why they are so huge in europe.
Old 01-29-2006, 07:00 PM   #17 (permalink)
sweet. can you PM me your shop info for future reference? Maybe I can swing by and check out your place next time I'm in town.
Thanks for the quick reply.
Mike
__________________
Old 01-29-2006, 07:29 PM   #18 (permalink)
i just read this thread and had to wipe the drool off my keyboard! a factory, turnkey diesel! dude, you just made my whole year! please post your contact info asap!
stumpbum21 is offline
Old 01-29-2006, 07:32 PM   #19 (permalink)
irott's Avatar
did you get it from jarco?
__________________
[1992 4runner Limited]
___________________________________________
3.Slow (155k miles and still running strong)
irott is offline
Old 01-29-2006, 07:33 PM   #20 (permalink)
SnoViking's Avatar
Send a message via AIM to SnoViking
i would love to go to a turbo diesel... did they make a larger diesel for the newer rigs?
__________________
Pat
1999 4Runner SR5 V6 4WD - Brush Guard, lift, Duelers, roof rack, acouple lights
~You will always be my little boy~
Hobbes
(11/28/05)
Future mods- more lift, tire gate, sliders, better lights, engine upgrades.
SnoViking is offline
Old 01-29-2006, 08:15 PM   #21 (permalink)
You can reach me at:
solohant@yahoo.com
phone number is: 210-683-9663
For the time being, we are performing the swap at a shop in Austin. If you have any questions, ask away. Yes, the unit is from Jarco. The one we have right now has 72,000 miles on it. I just purchased a timing belt/tensioner/water pump/idler pulley and factory coolant from Toyota for less than $300 complete. I always recommend doing this simple maintenance while you can easily get to it. You never know with these japanese half cuts. The mileage may be low but they idle alot in traffic. This makes for cheap insurance. -Todd
Old 01-29-2006, 08:44 PM   #22 (permalink)
what about fuel tanks and the lo press pump and lines? do you supply and install them or do i have to source a donor?
Old 01-29-2006, 08:57 PM   #23 (permalink)
The half cut comes with a diesel filler tube. You just take out the in-tank fuel pump. Crimp the wires powering the pump (outside the tank), then replace the missing pump with a length of rubber fuel injection hose, then cap off the breather tube going out of the tank. There is no low pressure pump or lift pump. The fuel pressure it maintained by the injection pump. -Todd
Old 01-29-2006, 09:03 PM   #24 (permalink)
i'm planning on dual tanks, any worries or advice?
Old 01-29-2006, 09:29 PM   #25 (permalink)
Where will you mount the second tank? Gas or diesel?
Tags
53l, canada, conversion, cut, diesel, europe, fj80, half, halfcut, import, jarco, registration, texas, toyota, vehicle, writeup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Diesel conversion: Auto or 5spd? 91diesel 86-95 Trucks & 4Runners 4 07-09-2007 01:18 PM
toyota diesel conversion finished Dieselyota 95.5-2004 Tacomas & 96-2002 4Runners 63 06-18-2007 05:03 PM
diesel conversion j Early Land Cruisers 1 01-25-2007 01:45 PM
Toyota Diesel Conversion Forum gohawks Off Topic Talk 4 01-16-2006 03:28 PM
What about these diesel engines for a conversion? DH6twinotter 95.5-2004 Tacomas & 96-2002 4Runners 7 03-17-2003 02:47 PM
2009 InternetBrands, Inc.
