Did I purchase the wrong repair manual??
Old 10-11-2016, 01:24 PM
Diego toyota's Avatar
Good day, one an all. I have a question hoping someone can help me, thanks. I recently perchased the Haynes manual 92075, Toyota pick ups & 4 runner, 1979 thru 1995.I am having cold starting issues on my 91 toy 22re. I was going through the
manual hoping I'd find some information on testing the Cold start injector, and the cold start injecter
switch. I don't see information on what and how to test using ohms. Can someone guide me, thanks.
Old 10-11-2016, 02:24 PM
muddpigg's Avatar
Look for a factory service manual. Used to have digital copies on YT.
Old 10-11-2016, 04:37 PM
robertd33's Avatar
MEASURE RESISTANCE OF COLD START INJECTOR
(a) Disconnect the cold start injector connector.
(b) Using ohmmeter, check the resistance of the injector. Resistance: 2 –4
(c) Connect the cold start injector connector
Old 10-13-2016, 02:50 AM
Staff
Terrys87's Avatar
I have never had the Cold Start Injector to fail. What fails is the Cold Start Injector Timing Switch, located under the Throttle Body. On the previous generations 84-88 it is the brown sensor. Sometimes just cleaning the Switch with a brass tooth brush will work. You can pull it out and put it in the freezer and follow Haynes Manuals resistance checks as the sensor warms up and the resistance should change as it warms up.
drednog
02-20-2019 08:52 AM
Barnes 4wd
Vendor Advertising
15
11-14-2016 12:16 PM
surf4life
09-19-2016 09:29 AM
JoeCat1221
07-05-2016 04:53 PM
Grinder41
07-02-2016 01:59 PM
Quick Reply: Did I purchase the wrong repair manual??
