Diagnosis help needed 3.0 Automatic
Old 06-12-2016, 02:06 PM
nekchris's Avatar
My 2WD 1993 V6 3.0 automatic transmission sometimes won't go into "L" gear. Fluid is full. It happens more often when engine is hot, less so when cold. Also the green back lighting is sometimes dim and sometimes bright, that goes for all the gears.
Old 06-13-2016, 07:33 AM
scope103's Avatar
Have you checked for codes?
http://web.archive.org/web/201408161...31diagnosi.pdf
On open #1 solenoid should throw a code, but you might have an intermittent problem.
nekchris
06-08-2016 09:05 AM
Dunryt95runner
3.4 Swaps
05-08-2016 07:45 PM
nekchris
04-11-2016 02:43 AM
Beau Baxter
03-25-2016 10:41 PM
Quick Reply: Diagnosis help needed 3.0 Automatic
