Deflector on Halfshaft
Old 08-05-2009, 11:04 AM
adphelps5's Avatar
This may be a stupid question and a no brainer but i replaced both the halfshafts (got them used and rebuilt for $40 for both) and got everything torqued down, went to put the snap ring back on and noticed it wasn't going to fit. When examining the halfshaft I noticed the deflector on the outer cv shaft was bent in areas. I was able to rebend most of it with pliers but had to use a c-clamp to get the snap ring back on. Was able to turn the halfshaft by hand still, was wondering if this may cause an issue later on and if i should just take everything back off and replace the deflector now?
Old 08-05-2009, 12:06 PM
OutlawMike's Avatar
Does it rub at all on the back of the knuckle? What was keeping the CV from seating all the way and not allowing the C-clip to engage?
When I put mine back in last weekend, I loaded a bunch of grease into the bushings in the knuckle. I could not get one of the C-clips to engage. The problem was the grease, it was loading up on the seal and had nowhere to go. I worked it a bit and was able to get the shaft to move in until the C-clip engages.
Mike
Old 08-05-2009, 12:13 PM
adphelps5's Avatar
yes there are two spots that is rubbing on the deflector, and the c-clip would not go back in until I used the c-clamp.
Socerlover
09-11-2015 01:31 PM
terminator
07-27-2015 07:13 PM
britishdudes2dr
07-25-2015 06:47 AM
HBoss
14
09-09-2003 11:04 AM
jharris2
06-29-2003 04:56 PM
Quick Reply: Deflector on Halfshaft
