Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Dashboard bulbs
So I've got the 1994 4runner and it's dash is pretty dark at night. Three or four bulbs are out and I've got to replace them. Two questions, how hard is it the tear the dashboard apart to get at all the lights? and has anyone replaced the standard filament bulbs with LED's?
I did a full conversion of LED's on my Acura TL and it turned out nicely. Just would like some info in anyone has run into issues or tricks to make that dash come off easier. Thanks, JMT |
| Sponsored Links |
#2 (permalink) |
there is a post about this...Search it
__________________
1987 Pick Up 2.4L 4x4 2004 Rallirt 2008 Taco |
#3 (permalink) |
Pulling the dash out is a PITA. It took me hours to do, just to fix something that took like 2 minutes.
__________________
1994 Toyota 4Runner SR5 4X4 208,000 miles and counting 3.0 V6, 5 speed 14/19 MPG city/hwy(before 33's) Current Mods Headers, 2.5" Flowmaster custom exhaust, K&N FIPK KC Daylighter 100 Watt lights Ranchos x4, 2" Lift Downey coils 33-12.50 M/T's, 1" t-bar lift, 1" body lift Tow pkg w/ lighthookups Silverstar Headlights, Pioneer Deck w/XM Brushguard 250Watt JLAudio 8" W3 Sub Future Mods
12V Aux outlet-400/800peak inverter roof basket/lights Air locker 4.88 gears H.O. Alternator |
#4 (permalink) | |
http://www.yotatech.com/f126/indiglo...4runner-75767/
its not the EXACT link, but the steps should get you by... the dash isnt that hard to do, but then again, it was the first time that i did it... now its a breeze...
__________________
Quote:
1990 Toyota 4RUNNER
3.0 & 5spd. | Custom Cat-Back Exhaust | Magnaflow Muffler | Pro-Comp Light bar | 2 5in. Pro comp Driving Lights | 33x11.5 BFG M/T k/a's 2005 Scion tC | Azure Pearl | 2AZ-FE VVT-i | Magnaflow Muffler | Tein S-Tech 2.5" Lowering Springs | Full Interior LED Swap | Drag DR8 Rims | Cold Air Intake | Kicker Subs |
#5 (permalink) |
It sure was hard for me the first time.
__________________
#6 (permalink) | |
well, if you ever need help with it again, then im just about ten minutes south of sac... and ive had my dash apart several times changing the stereos and trying to wire stuff uo, so its second nature now...
__________________
Quote:
1990 Toyota 4RUNNER
#7 (permalink) |
Thanks for the offer. I'm actually only in Sac a couple times a week now. I still don't like taking the dash out. A friend of mine had an old F*rd, and that dash was like 6 bolts.
__________________
#8 (permalink) | |
these ones are too, albeit with a few thousand clips and electircal plugs to disconnect... lol...
__________________
Quote:
1990 Toyota 4RUNNER
#9 (permalink) | |
yeah, the dash is a lot of fun to take apart, but it's gets quick and easy after you do it about 8 er 9 times, lol
I replaced my bulbs with some green LED bulbs that I got on-line, and I'm not impressed at all... their not near as bright as the filament ones that were in there before, and the next time I get reason to take the dash apart I'm taken em out. Also, the LEDs fool the dash light dimmer switch too because of the less power it takes to light them, so if I turn the knob I either just have on or off, no in between, lol
__________________
91 Pickup, 4wd, 22re, stock suspention, rollin on 31s... for now that is... 290 thousand miles and counting... Linkies: YotaTech photos MySpace Quoties: Quote:
#10 (permalink) |
That link for the Indiglo gauges is just what I needed for this project, thanks for linking me up. I've got it about a quarter of the way off right now, that should help me get it off. I agree with you guys, the first time you do something like this it's really hard because you don't know what will break or not break and how to pull the cowl off the dash.
Thanks for the help! John |
#11 (permalink) | |
Quote:
Oh man, the cluster is friggin EASY to pull out. I can get mine out in under 5 mins easily. I dont know what kind of leds you have, but mine work great in the dash. They are very bright, the dimmer works (to an extent) Right before they go completly dim they will just switch off. Just incase you wanna know.... Cluster uses: 3 #194 bulbs ( 2 more for the blinkers) and 2 # 194 bulbs (all the warning lights use # 74 too)
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#12 (permalink) |
My 1990 Surf with LED conversion in the dash....
![]() Wasnt too hard to do, it does suck pulling the dash tho...
__________________
http://www.cardomain.com/ride/2049644 http://www.myspace.com/cbrsport17 http://www.flickr.com/photos/cbrsport17/ Cryo Guy '90 Toyota Surf(4Runner)(SOLD)<-----I am going to miss this thing!! '95 Honda Saber( Acura TL)(selling) '04 Nissan Titan 4x4 '95 Toyota Lucida Luxury '92 Suzuki GSXR(The Daily Driver) |
#13 (permalink) | |
the main thing I dont like about my LEDs is how they light the dash... the light is "patchy"; it doesn't spread out... it's bright right where the lights are, and it fades everywhere else...
can kinda see the same effect with yours cbr
__________________
#14 (permalink) |
yea it does, you can really see the patchy look at night...someone recommended filing the bulbs down a little bit, but i havent felt like pulling my dash again...
__________________
#15 (permalink) |
WLED-x5 LED Wedge Base Bulbs from http://www.superbrightleds.com/mini-wedge.html
They shoot light from 5 sides and are far less patchy than other LEDS, plus they are completely controllable from the dimmer. I'm in the process of adding an oil pressure and temp gauge from Autometer and I've lit them with the same bulbs. I'll try to get pics posted, depending on how successful I am building a two gauge pod.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#16 (permalink) |
x2!!
I used the WLED-x5 leds from superbrightleds.com. Heres how my dash looks.. In that picture the bulb on the drivers side was only half working, I fixed it but never took another picture... ![]() Don't forget the heater (bad picture) ![]() I also replaced the lights in the ashtray, most of the idiot lights, turn signals and my corner lights.
__________________
#17 (permalink) |
They really do make a difference. i loved the difference compared to bulbs with condoms. i used bright white and black lights in different areas.
__________________
-Phyl 1991 Hilux Surf SSR-G Petrol 3.0L V6 193,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l TOYOTA TOUR 2008 トヨタ|NEVER QUIT
#18 (permalink) | |
that looks great guys... i have a friend of mine in our scion car club that is the electrical/led guru, and he warned me that the LEDs will give off patchy light... imma order some of those WLEDs and show him what for...
__________________
Quote:
1990 Toyota 4RUNNER
#19 (permalink) | |
Quote:
__________________
