YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 06-08-2006, 04:49 AM   #1 (permalink)
Personal Sales Rating: (0)
Cylinder head removal questions. Fastest way to do it?
My time is very limited and skills as a mechanic aren't much better. Actually, I'm ok with the wrench, but rarely tackle the big jobs since I don't have much time now. Between flying cargo at night, building houses during the day, taking care of the kids, my Mom's place, Mother-in-Laws place, etc., etc.,, I don't have much time to work on the 4runner.
I do have the service manual for my 89 4runner. Seems like they make you take extra steps on certain things. Here's my question:
I want to remove the cylinder head on this truck for a total rebuild on the top half of the engine. I have the rocker and camshaft already removed. Can I simply unbolt the exhaust manifold and intake manifold at the head, or do I have to do what the manual says and start further "downstream", pull the head, and then remove the intake from the head?
Tips on this? Thanks.
vmax84
Click the image to open in full size.
vmax84 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 06-08-2006, 06:57 AM   #2 (permalink)
InternetRoadkill's Avatar
If you want to just pop the head, then yes, you can remove the intake and exhaust manifolds while the head is still on the engine. Some of the bolts on the intake are hard to get too.
Don't forget to remove the ground wire in the back. Also, there is an allen head bolt which is not apparent and often overlooked which hides near the base of the thermostat housing.
InternetRoadkill is offline
Old 06-08-2006, 02:46 PM   #3 (permalink)
Threadstarter [OP]
Why would they want you to "break the intake manifold" down further than it needs to be? Won't that just require more gaskets?
vmax84
vmax84 is offline
Old 06-08-2006, 03:25 PM   #4 (permalink)
kyle_22r's Avatar
i think it's a little easier to pull with the manifolds off, less weight to lift in an awkward position. however, you'll probably at least need to remove the top half of the intake to get at the electrical connectors and unplug them. i recommend unplugging the wiring harness from the ECU and pulling it through the firewall(not nearly as difficult as it sounds).
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
22, 22re, cleanup, cyclinder, cylinder, easiest, engine, head, heads, instructions, reinstallation, removal, remove, remover, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22RE cylinder compression/ engine removal and swap questions the4x4runner 86-95 Trucks & 4Runners 6 07-25-2006 02:48 PM
Cylinder Head Removal - Necessary to remove crank bolt? bsanders30096 86-95 Trucks & 4Runners 1 05-15-2006 01:48 PM
Ignition Cylinder removal? hafftrak 95.5-2004 Tacomas & 96-2002 4Runners 3 07-29-2005 11:35 AM
Cylinder Head Gaskets Recall Questions johnkay 95.5-2004 Tacomas & 96-2002 4Runners 12 12-25-2004 01:37 PM
Cylinder head removal question... PhattieD Maintenance & Repair Archives 0 06-26-2002 07:08 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
