cv shaft vibration?
Old 10-18-2013, 04:44 PM
4x4flatbed's Avatar
cv shaft vibration?
Can worn cv shafts cause i vibration even with hubs unlocked in 2wd? i get a bad vibration/shake around 45-50 nomatter what, speeding up slowing down coasting, anything. i found both shafts have some play but they arent moving with the wheels when the hubs are unlocked right?
Old 10-18-2013, 04:53 PM
sinneDBTB's Avatar
if your hubs are unlocked then it sounds like u-joints
Old 10-18-2013, 06:10 PM
Teuf's Avatar
I vote rear U joints in the rear driveshaft....
Old 10-19-2013, 06:33 AM
4x4flatbed's Avatar
but all the shake is in the front end coming through the steering wheel, i can take my hand off the wheel for a second and hardly feel anything in the seat/floor. i also tried swapping out the 32s for stock size tires up front and its a little better but still there
Old 10-19-2013, 07:14 AM
rworegon's Avatar
Worn suspension/steering parts
Something broken
Something not tightened properly
Old 10-19-2013, 07:20 AM
250000_yota's Avatar
I'm with Oregon. When I my idler arm was bad on my truck, I had a vibration between 45-50, thagot worse over time. Check your front suspension components and go from there.
Old 10-19-2013, 07:54 AM
4x4flatbed's Avatar
just gave the front end a good once over, everthing seems good and tight except the driver side upper ball joint has some play. going to grab one and swap it out hopefully she rides like a cadillac again
Old 10-19-2013, 11:29 AM
4x4flatbed's Avatar
no luck with the balljoint. idler arm had just a tiny tiny hint of play so ill try that next. if thats not it ill rebuild the whole front end
kawazx636
10-06-2021 03:03 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
JPV
09-28-2015 03:15 PM
Odin
09-26-2015 06:56 PM
Quick Reply: cv shaft vibration?
