cv shaft replace or not
I am in the process of istalling 4.88s in my pickup its got the basic 4 inch lift. Im wondering if while I have everything apart if I should go ahead and spend the money new shafts or if I would be better off leaving the old ones in there the boots look good and Ive never had a problem with them before I believe they are factory parts. Just running low on funds and the extra 140 or so could be spent elsewhere.
yup... if it isn't broke don't fix it... unless you have the coinage.
in general, if the boots aren't compromised / squirting grease, and it's not clicking, grumbling or vibrating, the joint is fine.
If you are going to rebuild, Downey makes neoprene boots that supposedly will take more angle without ripping.
I have no experience with them, but have thought about picking up two sets.
Mike
Mike
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
01-10-2016 10:18 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Iceman4193
07-15-2015 04:48 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
