CV Joint - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-07-2008, 06:09 PM   #1 (permalink)
addicted56's Avatar
CV Joint
I'm kinda new to IFS front suspension but I think I have a problem with my drivers side front CV joint.
Today I put on some larger tires and I heard a small clicking sound at 10-20 miles per hour. After that it goes away and below that I can't hear it it all. I've only driven the truck 30 miles total so I haven't had much time to see if it was there before.
I thought something was rubbing at first but I got out and checked and nothing. Then I went feeling around and the CV shaft is loose and moves around a bit. On the other side it doesn't do that.
I guess the question is
#1: Could the larger tires brought to my attention this problem that the other tires were not. I'm thinking there is some more stress on them (now running some 32's just for fun for a week over the older 31's.
#2: How long can I go before needing to fix this before some major problems.
#3: How long a job is it and how much does it run if I do it myself.
Thanks you.
__________________
Addicted to all thing automotive.
1956 Ford F-100 (Cummins 4bt)
1997 Ford F0250 (Power Stroke)
1989 TOY FJ62 (3FE)
addicted56 is offline
Old 09-07-2008, 06:13 PM   #2 (permalink)
bigarms23's Avatar
the larger tires probably addressed a problem that you weren't aware of. i would have a driveshaft shop look at it before i could give a period of time before it breaks or gets worse
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits
1972 stepside jimmy d44/d70 425hp
1995 green range rover
bigarms23 is offline
Old 09-07-2008, 06:23 PM   #3 (permalink)
tc
tc's Avatar
Do you hear the clicking when going straight, or only turning?
ADD or manual locking hubs?
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 09-07-2008, 07:09 PM   #4 (permalink)
toyminator2000's Avatar
Turn the stereo up louder and that noise will go away.
__________________
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE
toyminator2000 is offline
Old 09-08-2008, 05:53 AM   #5 (permalink)
addicted56's Avatar
No I do not have manual locking hubs. So I guess I have ADD.
I hear the clicking going straight and when turning. It doesn't seem to matter. But I only hear it between 10-20 miles per hour. Below and above that speed it is completly gone. But when I hear it, it makes is self very obvious with the window down.
I'm now running 32x11.5x15 rvt mud tires and before it was some old 31x10.5 TA tires. Definetly notice the extra weight and increased rolling resistance in these mud tires.
__________________
1989 TOY FJ62 (3FE)
Old 09-08-2008, 12:04 PM   #6 (permalink)
Matt16's Avatar
The tires could not have cause the problem as from the sounds of it, you haven't been in 4x4 yet- thus no torque transmitted to the CV.
32" tires are well within the safe range for CVs, I've heard of 35's being handled without to many breaks.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 09-08-2008, 12:45 PM   #7 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
with the wheel on the ground, if you can grab the axle half-shaft and turn it, and see motion between the shaft and the outer CV joint, there MAY something wrong with the CV joint. strictly speaking though, there should be little to no play visible in the outer CV joint, but you may see some anyways because of the effects of the auto-locking hub.
installing the larger tires though should not have any affect on the CV joint though since they actually make the CV turn slower than normal (with auto-hubs/ADD).
any chance when the tires were installed that the shop used the stick on lead weights to balance the tire and they are in a different location that may be tapping against the upper control arm or brake caliper?
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 09-08-2008, 03:10 PM   #8 (permalink)
addicted56's Avatar
It is a possibility I guess that the weights are tapping. I looked behind and tried to see if anything could be hitting but it didn't appear so and nothing was rubbing.
I took the wheels with tires off of my Land Cruiser FJ40 so there could be a lot of things I guess. I just figured it was the CV since it wiggles back and forth a lot on the drivers side. I will check to see exactly where the movement is comming from. I'm only running these tires a week or two until i sell the FJ40, and am just doing it for the heck of it and the other tires that I got on the thing were bad.
I did put it in 4WD but with the other tires and heard nothing after putting it back in 2WD and driving a few miles. It was after that 3 mile drive that I put the other wheel tire combo on.
I guess I will see in a week when I put the stock tire wheel combo back on if I still have the same noise. Maybe I am just rubbing on something on that speed. Just wondering why it doesn't do it all the time if it is a rubbing issue.
__________________
1989 TOY FJ62 (3FE)
Old 09-08-2008, 03:25 PM   #9 (permalink)
Benny_Wiskas's Avatar
You may have already tried this, but go to a parking lot, cut your wheels, and just move real slow. I've got a cv going bad and you can hear the clicks and feel them in the steering wheel if you're barely moving.
Benny_Wiskas is offline
Old 09-08-2008, 04:13 PM   #10 (permalink)
so it's not just an "I put new wheels on" but an "I put new rims and tires on."
these things are important when asking for people to help diagnose problems.
no offense to you intended, just something to think about.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
CV joint saulgoode 95.5-2004 Tacomas & 96-2002 4Runners 8 07-08-2008 01:25 PM
U-Joint? Trustyrusty 86-95 Trucks & 4Runners 2 04-06-2008 09:04 AM
U joint???? epic37311 95.5-2004 Tacomas & 96-2002 4Runners 2 02-15-2005 12:08 PM
CV joint, again az4x4runner 95.5-2004 Tacomas & 96-2002 4Runners 1 11-02-2002 09:48 PM
CV Joint az4x4runner 95.5-2004 Tacomas & 96-2002 4Runners 3 11-01-2002 01:09 PM
2009 InternetBrands, Inc.
