| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
CV Axle replacement help
#2 (permalink) |
Search "cone washers".
Here's a good thread with lots of different ways described. http://www.yotatech.com/f116/cone-wa...l-hubs-118905/
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! |
#3 (permalink) |
I found tapping on the side of the hubs with a hammer worked, not hard enough to dent them but not too lightly either. And leave the nuts on the end of the studs a couple of turns, trying to find the cone washers after they shoot off at Mach 1 can be a PITA.
#4 (permalink) | |
Yeah...what Eric said. Take about a 3 pound sledge and hit the hub right above the stud. Be sure and have the nut on the hub. I can see a bit of a flat spot in your pic where it looks like it's been done before. Put anti seize on them when you replace.
I replaced the studs on the front diff flange with bolts so it's real easy to replace the CV's next time. Good luck
__________________
thefreqofnature Quote:
#5 (permalink) |
Thanks guys. Thats not actually my pic, I stole it from somewhere else to help get the point across. Im trying that first thing in the morning
#6 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Just a suggestion.....
A 3lb'r will work, for sure. But, I've just used a ball peen hammer (flat end) resting against the hub above each washer/stud (with the nuts on) and then strike that with another hammer. Seems to have less impact on potentially ding'n up the hub and much less chance of accidentally striking a stud. Of course, PB Blaster first...
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| CV Axle questions Boot vs entire axle? Quality? | BornChaos | 95.5-2004 Tacomas & 96-2002 4Runners | 19 | 02-28-2008 02:10 PM |
| Write-Up: CV Axle Replacement for 3rd Gen 4R & Tacos | Roadrunner | Maintenance & Repair Archives | 2 | 05-10-2005 11:53 AM |
| CV Axle replacement on 2nd Gen? | Yota4runner | Maintenance & Repair Archives | 17 | 04-23-2005 07:39 AM |
| Cv Axle replacement | Praufet | Maintenance & Repair Archives | 9 | 04-01-2005 05:34 PM |
| cv axle replacement | Steve28 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 01-25-2003 07:23 PM |
