CV axle replacement- axle too short?
Old 06-21-2011, 08:33 AM
snaglak's Avatar
Hello all, I am currently meandering my way through replacing my cv joint axles. I bought refurbished ones from advance auto, and after sliding the first one into place, it seemed to be too short. I took it out of the steering unit and compared it side by side with the old one, and it was about an 1 to 1/2 inches shorter. Is this a problem? It seems like I can stretch it out a bit, but that seemed like it may stress the unit in the long run. Input please? Oh, and it's an 86 pickup 4x4.
Old 06-21-2011, 09:48 AM
snobdds's Avatar
If they don't look identical side by side, then it is the wrong one. I would double check with advance auto to make sure they got you the right one.
Old 06-21-2011, 09:51 AM
jessed59's Avatar
they must have given you the wrong ones.. maybe from a newer model have you pulled both sides and compared? one might be longer than the other so double check that you wanna be sure to get the right length or stuff can strip/blow out
Old 06-21-2011, 10:52 AM
blake.nemitz's Avatar
you got the wrong ones and if i am correct they are the same length for both sides
polo451
13
11-20-2016 07:49 PM
Jcrawl94
10
10-24-2015 04:34 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
88sasturbotoy
08-11-2015 01:56 AM
rustym
08-07-2015 10:39 AM
Quick Reply: CV axle replacement- axle too short?
