Cup Holder
Old 05-02-2009, 02:51 PM
scorp965's Avatar
Cup Holder
I have a 1990 Truck with the pull out cup holders (that block the AC vent), one of the metal brackets has gone missing, so when I insert a beverage, it falls through; I tried to create a replacement using a coat hanger, but the gauge was not thick enough, and it didn't stay in place.
Can I order these metal brackets by themselves, or do I need a replacement cup holder assembly? Where can I obtain this part, the dealership ($$$)? Also, does anyone know what years had this cup holder style? It seems pre-1990 trucks had no cup holder, and later years had them in a center console?
Old 05-02-2009, 03:30 PM
deez4wdsparechange's Avatar
junk yard i got a replacement for mine really cheap
Old 05-02-2009, 04:28 PM
space-junk's Avatar
idk about you, but in my 90 4runner i dont have metal brackets... its a piece of flat plastic that drops down when you pull out the holder... just an FYI...
Old 05-02-2009, 04:48 PM
scuba's Avatar
Troy, next time you pull out the holder look at the inside top corners where the flat plastic peice connects to the top piece, youll see the little metal peices the OP is speaking of..
but yeah, you can probably get a 5 finger discount on one at a boneyard..
Old 05-02-2009, 05:23 PM
MIKEMOKAS's Avatar
when i first got my truck it was missing both, and when i got my 4runner it had one homemade jobby in it, i think it was the shaft of a long nail.
anyways, after a couple trips the the junkyard both trucks had the factory pieces in them..
another good thing to do is pull the front dash facia off and gently pry out the air vents from behind and get those little air vent bushings, because if you ever pull yours out, chances are that they will crumble into dust..
ttyl!
Old 05-02-2009, 05:34 PM
iamsuperbleeder's Avatar
I remember discussing these in a previous thread a while back...
I would say a junk yard is probably your best bet, but I had seen entire cup holder assymbely's on eBay as well
Old 05-02-2009, 05:59 PM
Justinlhc's Avatar
I hardly use mine. Seems ridiculous to place a cold drink in it during the winter because your heater will warm it up in no time. In the Summer I guess it's not so bad, but out here I need all the air flow I can get.
shooter86314
01-07-2016 07:05 AM
Fofo
09-14-2015 01:39 AM
Peevedkitten
11
08-31-2015 06:57 PM
TJWilly
07-31-2015 02:05 PM
defrag4
07-31-2015 10:50 AM
Quick Reply: Cup Holder
