CSB Nightmare!!!
Old 11-05-2013, 06:24 AM
Airborne173rd's Avatar
CSB Nightmare!!!
Ok gents, so I'm really stumped on this and I need some help. I've read ALL applicable threads related to my issue and there seems to be no help in them. So, 89 v6 xtracab 4x4...center support bearing went out recently. Replaced it. Went bad again in two weeks. Replaced it. Now less than 2 weeks later, the end of the driveshaft is rubbing on the metal portion of the CSB, which is what it was doing with the first replacement as well. The CSB assembly looks as if the front is angled towards the bottom of the bed and the rubber grommet is bulging out the rear of the CSB. It almost looks as if the crossmember portion of the CSB mount is bent torwards the bottom of the bed. The most recent replacement to go bad was the one from driveline parts.com, the $40 one. First one was the advance auto one for $135, yeah, never again. Truck has stock suspension and I'm running 32x11.50 BFG km2s. I'm stumped. Please help. Got a couple of pics. Let me know if you need a better angle...😕 Name:  2AAA5EC4-F557-4AE0-98DC-D2A56409F738-202-0000000AC90D46F2_zps89a3f6fb.jpg
Size:  74.5 KB Name:  BDFD258D-7206-43C4-9F91-AAC8AC4D5A69-202-0000000AD41FC746_zpsa4dbb9ea.jpg
Old 11-05-2013, 08:29 AM
HighLux's Avatar
Have you had driveshaft checked for balance?
Old 11-05-2013, 12:39 PM
The driveshaft itself is balanced, I'm pretty sure the problem lies within the mounted angle of the CSB, just not sure why or how....
Old 11-05-2013, 01:48 PM
Gevo's Avatar
you don't feel any vibration or hear anything unusual?
I would put the rear end on jacks and put it in gear, get nearby and inspect the shaft in motion... perhaps something will reveal itself. Otherwise I don't have experience with this part.... yet..
Old 11-05-2013, 02:03 PM
Yes, I hear the driveshaft rubbing the metal outer portion of the CSB. The way the CSB mounts to the crossmember allows it to be ok for a while and the odd angle eventually wears the CSB out and pulls the bearing out of the center of the grommet...It's not a balancing issue though.....
Old 11-05-2013, 03:12 PM
HighLux's Avatar
i know you said driveshaft is balanced...but did you actually take it to a driveshaft shop....and have it balanced? going off someones word?
Old 11-05-2013, 03:35 PM
Toyota~Boy's Avatar
Also check your u-joints and make sure there tight. Does those rear drive shafts slide apart kinda like a slip yoke. If so check the splines they could be sloppy. One more thing. Does those carrier bearings go on one way only. If not try turning it around. You may have it backwards.
Old 11-05-2013, 03:39 PM
Teuf's Avatar
Ditch the center carrier and have a full length driveshaft made.....
Old 11-05-2013, 04:00 PM
U joints are tight, and no slop in the slip yoke. I haven't had the driveshaft balanced since I owned the truck, but I never noticed any vibration. It hasn't been off road so I know it hasn't contacted anything throwing it off balance. I installed the CSB with the cutouts in the flange facing towards the rear of the truck which is the way specified in the FSM. If you look at the way most of the rubber grommet is bulging out of the rear of the CSM, is this normal? When I get the new CSB I may have to drill out new mounting holes where the CSB mounts to the crossmember to put the bearing into proper alignment, but this shouldn't seem necessary. I would just put a one piece driveshaft in but I'm worried about the pinion angle and really don't want to have to shim the rear axle to make up for losing the double cardan joint. When replacing the last 2 CSB's I was VERY careful to mark the shaft and put it back together the same way it came apart. Still puzzled....
Old 11-05-2013, 04:14 PM
At least so I know my options, what does a 1 piece shaft usually run and where is the best place the get one made?
Old 11-05-2013, 04:33 PM
Teuf's Avatar
Any reputable driveline shop can configure this.
Old 11-05-2013, 11:55 PM
wyoming9's Avatar
Red face
Just curious just where did you get the bearing ??
Could it be a one size fits all??
It could just be that poor of quality.
It is really hard to tell but it does not look that hard to line things up so it works .
Me I would go with a one piece drive shaft and be done.
Old 11-06-2013, 12:07 AM
Staff
Terrys87's Avatar
I provided an old drive shaft to a driveshaft shop and if I recall right it around $75 for his work for him to shorten it. They will have plenty of pipe laying around that it shouldnt cost much to have one made if you decide to go with the one piece, make sure your angle wont be too sharp if you do the one piece. You may need to drive a ways to find one as the economy did shut a few of them down in my area.
Old 11-06-2013, 07:51 AM
Well this thread has seemed to move towards the way of me going the one piece route, but I'm still curious as to why this is happening...
Old 11-06-2013, 07:59 AM
CJM
CJM's Avatar
When you installed it, you did put the nut on there right? And made sure to push the nut in so it cant back out right?
Old 11-06-2013, 08:01 AM
Yes, the nut was staked....
Old 11-06-2013, 08:19 AM
hossdog's Avatar
I had my buddy press mine on to the shaft for me and it was backwards when I went to hang it. Would have been easy to mount it that way if it didn't have the hangers on it I would have never noticed as the bolts still lined right up. My money says it's on backwards.
Old 11-06-2013, 08:24 AM
hossdog's Avatar
Also when I finally got mine in right it still seemed like it wasn't perfectly aligned, so I took a bar and carefully pried between it and the the frame until it bent slightly so that the it lined up right. Then went for a drive and checked it again. I think that assuming these are going to line up just perfect out of a box from NAPA might be reaching a little.
Foage3z
Florida
08-31-2015 04:49 PM
Trevor FNG
11-11-2007 06:32 AM
BluYot
09-15-2007 03:06 PM
85 4runr
08-05-2004 02:46 AM
Quick Reply: CSB Nightmare!!!
