Crappy idle + Rev limiter = Good idle???
Old 04-07-2008, 04:56 PM
91Toyota's Avatar
I've been having the worst idle ever. I was told it's a vacuum leak. I sprayed starting fluid ALL over the hoses, on the side of the engine, the valve cover, I tried reaching the back...and nothing changes. I unplug the PCV and my truck dies. Warmed up it idles at 1500-1700 then when I hit the brakes it idles at a 1k then to 1300 then to 1k again. It's extremely annoying. The idle screw is all the way down. So, what else should I do? Is there an easy way to adjust the TPS? When it's doing that I will rev it to 6k and let off until it hits 5500 then do it again like 10 times and it idles at 1k rpm just fine...that's whats so weird. Any suggestions or thoughts?
Old 04-07-2008, 05:08 PM
TOYOTA 1's Avatar
ya mine does the same thing its wierd. i notice if i get low on water "because of small hg leak" my truck will surge like that then i will add water instantly goes away. or if i dont add water and just run the out of it it will idle fine.
ive herd that the brake booster could be the culprit. if you fix it please repost. so i can try to fix mine. hehe
MidtownYota's Avatar
brake booster?
______________
90 toyota, 22re, 5 speed
Old 04-07-2008, 05:11 PM
TOYOTA 1's Avatar
ya i dont no thats just what i heard. somthing to do with vaccum leak or somthing.
Mine does the same thing. After it is warmed up, about 15 min of idling, it will start do 'surge' and this increases everytime you hit the brake. If i am at a stop light, it will surge a lot and it sounds like i am hitting the gas and then getting off it fast. I was told this would stop if i replaced the brake booster.
_______________________
Old 04-07-2008, 05:13 PM
TOYOTA 1's Avatar
same here just didnt think that would cause it.
Old 04-07-2008, 05:25 PM
91Toyota's Avatar
lol...I don't know about the brake booster...I think I am going to cap the brake booster vacuum line and run it until it heats up...that way I can count it out...lol
Old 04-07-2008, 05:30 PM
TOYOTA 1's Avatar
good eye! post results please!
Old 04-07-2008, 05:48 PM
91Toyota's Avatar
Didn't do a damn thing
I am thinking of loosening the tps and turning it until it runs right. Not sure if that is the way to do it...but I suspect that is what is happening.
Old 04-07-2008, 05:50 PM
TOYOTA 1's Avatar
ya i didnt understand how it could be the booster. but i dont understand alot of things hehe.
Old 04-07-2008, 05:54 PM
91Toyota's Avatar
yeah...lol. This is getting extremely annoying. I am getting to the point I just want to sell it and be done with Toyota forever
Maybe this is our solution...hope it helps someone....http://www.ttora.com/forum/showthread.php?t=53048
Never mind, that is a fix for hesitation!
06-01-2021 01:51 PM
Eggslinger
06-08-2019 03:32 PM
mengquis
07-13-2015 10:39 AM
Jnkml
07-06-2015 01:20 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Crappy idle + Rev limiter = Good idle???
