| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#51 (permalink) | |||||
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
#52 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Yeah, then you can put a torch to the stud nuts (that sounds funny...doesn't it?) to get the manifolds off for cleaning up the heads. Unless, you can pull the whole stud out....which might wind up happening, anyway. Most of mine came out that way...the nuts were so frozen up.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#53 (permalink) |
How hard was it to break loose the manifold to exhaust nuts? Did you use anything in particular to help them along? (I found PB Blaster to be OUTSTANDING on temperamental exhaust nuts)...
I'm experimenting with colors; how'dya like them?!?
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ Last edited by TNRabbit; 03-06-2007 at 10:42 AM. |
#54 (permalink) | |
The PB Blaster is definitely the best IME. But, if they're really frozen up (rusted/welded together) then you'll probably have to apply it several times...which means a bit of a wait. However, WD-40 (was out of the PB), a good socket and brute force was all I used....and wherever I could get a cheater bar in. It's a tight spot, so I used extensions (1/2in) also. Taking the wheel off would help, too. As I recall, there were some angles all I could get on was a box wrench, so I doubled a couple up for leverage. God!!! That was one slow going part of the job! Have fun...try not to bust a nut (pun intended).
__________________
#55 (permalink) |
that very fruity lol!
__________________
89' 2wd Toyota Pickup - 3vz-e, Custom Cold Air Intake, Flowmaster Exhaust, Lowered Suspension, Custom Rims, Black Paint Job, Extensive Sound System to find out more Click here....http://www.cardomain.com/ride/437849/6 |
#56 (permalink) | |
The colors...I just noticed that..haha! The stress isn't getting to you, is it? LOL!
__________________
#57 (permalink) |
Is this the same shoes as on ToyotaNation?
__________________
#58 (permalink) |
Request for Assistance:
I'm requesting opinions from EXPERIENCED (i.e., you've done this before & know what you're talking about) folks regarding decking, quench, etc., while I've got her apart. Please take a look at this thread & let me know what your opinion is regarding doing more than a simple HG replacement. Thanx!
__________________
#59 (permalink) | |
This is something new on me, but I just did some reading on it. Considering having some adjustments made? I guess I should say "serious" adjustments.
What will you have to do....machine the block down or lengthen the piston?
__________________
http://www.yotatech.com/misc.php?do=flashchat Last edited by thook; 03-07-2007 at 10:24 AM. |
#60 (permalink) |
__________________
#61 (permalink) |
Nobody...?
__________________
#62 (permalink) | |
Wish I could help you TNR, but that's outta my league. I'll root for speedy assistance, though!
__________________
#63 (permalink) |
Well, got the heads pulled today. Here's a link to the all the pics so far:
http://www.putfile.com/tnrabbit/images/89906 And here's the short version...got the pulleys off the main shaft for pulling the oil pump later: and took out MOST of the oil pan bolts. How the heck do you get the ones in back out?!? had to use FOUR socket extensions & my torqure wrench to get these effers off: this little sucker was hiding under a shroud under the intake manifold; you CANNOT get the heads off with manifold intact without pulling it and the following ones (10 mm, five in all): and this one is hiding on the backside of the right head: Right cylinder bank: and Left cylinder bank: See any evidence of blown headgasket here? Or here? Right bank head: Left bank head, #2 cylinder: No carbon buildup to really speak of: And I'll be darned if I can see any evidence of a blown head gasket or obviously cracked head!! Here's some pics of the #2 cylinder, cross hatching intact--woo hoo! Does anyone see any reason why I would have coolant in the #2 cylinder? Maybe crack head up behind the valves/guides?? Any other ideas? BTW; all the other cylinders looked like this; a little toasty?
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ Last edited by TNRabbit; 05-31-2007 at 03:20 AM. |
#64 (permalink) |
Here's the culprit:
the dark, rusty looking spot on the HG. Everything else looks good. I've sent an oil sample to Blackstone Labs; if it doesn't show any abnormal bearing wear, I'm going to stick with my original plan to change out both HGs, oil pump, & timing belt. If there are bearing issues, I'm going to go with the complete engnbldr rebuild. Wish me luck!
__________________
#65 (permalink) |
Big day! Got my Blackstone Labs report: They said there was some wear on the bearings & cylinders, probably caused by the antifreeze in the oil, but that the oil still had a good amount of wear protection in it (with 8500+ miles!). Looks like I can run my Mobil 1 for 10,000 miles if I change the filter @ 5k.
Ordered a spindle nut kit, clutch foot cover, and shifter bushing from MarlinCrawler. Ordered a machinist's tool set from Sears: http://www.sears.com/sr/javasr/produ...seBVCookie=Yes Ordered the Master Engine Kit from Ted @ engnbldr.com; he was extremely helpful, talking engine stuff with me for a good 15 minutes before I ordered the kit, PLUS they are having a SPRING SALE (!) so I got the entire kit delivered for only $378.00...WOO-HOO!! (a savings of $36.00) Ted thought my increased compression readings were probably from the head being machined when the HGs were done in 1998 (before I bought the truck). No way to know for now. I'm waiting on delivery of an engine hoist from Northern Tool on Friday. I'll have the engine out before I head for Puerto Rico on Sunday!
__________________
#66 (permalink) |
Did Ted say anything to the positive or negative about the higher compression? Will that affect future head gasket issues....
that machinest set looks nice -- Have you dropped your block and heads off at the machine shop yet? whats the word - I need all the info i can get here.... Kat
__________________
95 4runner 2wd 3.0 v6 Downey headers (dont buy them) Downey 2 1/2" full exhaust/Carsound cat Weasy2k cams/ENGNBLDR's o/s valves ported and polished heads/intake New project- 94 4runner V6 4x4 A/T 3" 4Crawler BL on order 33x12.5 BFG A/T's on 15x8 Cragar Black Steel Wheels 90 4runner 4x4 3vze Auto parting out - let me know if you need anything! 85 4runner, SFA, 22re, 5speed parting out |
#67 (permalink) | |
Quote:
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ Last edited by TNRabbit; 05-31-2007 at 03:24 AM. |
#68 (permalink) |
Did you get the fancy red one like i have? its a life saver sometimes - I used it to unload my new 8" jointer yesterday (700 lbs) **see how i stuck a tool gloat in there**
What kind of compressor is that? i got the IR 5s5(something like that) from Northern in Nov or Dec... I am loving air tools! I reccomend an AirCat NitroCat if you need an impact gun.... Sorry to get off topic but you started talking about tools! kat
__________________
#69 (permalink) | |
Quote:
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ Last edited by TNRabbit; 05-31-2007 at 03:25 AM. |
#70 (permalink) |
I guess your ___ is bigger than mine - I mean your compressor blows more than mine - I mean...
![]() I only have 5hp and 18 cfm at 90 psi -- and i thought i went overboard - Nice compressor you have there though... What kind of impact are you using?
__________________
#71 (permalink) |
ummm.....oooookaaay....*must...control.....urge... ..to make sexual inuendo comments*
Most of my air tools are HD Campbell Hausfield; not the best, but I got them SuperCHEAP on eBay. I have a really nice Chicago Pneumatic air drill and a Craftsman Professional Air Grease Gun as well. *brag*
__________________
#72 (permalink) |
i have been wondering who buys those air grease guns -- now i know...
__________________
#73 (permalink) |
It makes short work of the MULTITUDE of grease fittings on my truck...
__________________
#74 (permalink) |
Oh yeah-I forgot! I also sent my injectors off to witchhunter.com..
__________________
#75 (permalink) |
Well, I'll be coming back to MD from San Juan tomorrow! (yuck)
SO, I'll be pulling my engine out this weekend. Until then, here's some pics from San Juan to keep everyone entertained: Over the city (from a helicopter): Some views of the airport & rain forest in the background: And the beach: I actually hiked to the top of this mountain last Saturday:
__________________
| Tags |
| 47, compression, crap, fdasdfasdf, gasket, ghost, head, liter, overheated, replaced, rings, test, what |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Head Gasket | corvettelvr73 | 86-95 Trucks & 4Runners | 13 | 03-28-2007 02:18 PM |
| Cracked Head or Blown Head Gasket? | StevenR | Maintenance & Repair Archives | 5 | 06-14-2005 10:49 AM |
| Replaced Head Gasket, but not Head Bolts -- How bad is this? | The Rusty Gear | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 09-13-2004 08:03 AM |
| Head Gasket ? | Doc279 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 07-17-2004 11:44 AM |
| giving head... | 94 First Responder | 86-95 Trucks & 4Runners | 7 | 05-31-2002 01:22 PM |
