crankshaft to a/t mounting question
Old 03-10-2012, 10:10 PM
rockthepouch's Avatar
hello all-
I am mating my rebuilt motor up to my '91 4runner auto. I noticed on my new crank (from '03 donor motor) that there is a bearing in the middle...?
Could that be because my donor motor was out of a manual 5 speed?
Here is what the "nub" on my transmission looks like. It seems as though that would go back and fit behind where that bearing is...
When I removed the original motor I didn't see one and it looked as tho those two mated together well.
Here is
Old 03-10-2012, 10:49 PM
infart
Old 03-11-2012, 04:22 AM
Bassmastry101's Avatar
Well it looks like it's time for a manual swap!
The input shaft on a manual slips into the pilot bearing in the end of your crank. Since your bolting it up to a automatic you don't need it. Remove the pilot bearing and the "nub" should slide into it's spot.
Old 03-11-2012, 08:18 AM
dntsdad's Avatar
Are you doing a 3.4 swap into your 91?
Old 03-11-2012, 09:49 AM
Staff
DeathCougar's Avatar
That would be a pilot bearing for a manual trans. Remove the pilot bearing, and the converter fills the void when its all bolted together.
You said the motor is from a 2003? So..that means you are doing a 3.4 swap then?
06-01-2021 01:51 PM
coffey50
07-28-2015 10:55 AM
Jonny246
07-24-2015 12:37 PM
MTLroadierunner
07-20-2015 03:07 PM
Quick Reply: crankshaft to a/t mounting question
