crank wont turn
Old 05-22-2007, 06:28 PM
hogie9ll's Avatar
Smile crank wont turn
ok here is the thing just got my 30 over block back with pis rings and over berrings,,,,,i titened the crank down to only 40 ft pounds , and i couldnt turn it by hand.....should i just pay 200$ to have a ase put the crank,pistions,rings,timing and head together 4 me.......this truck is a bam headach....DAVE , ps what the hell is wiki?????
Old 05-22-2007, 06:44 PM
1994runner's Avatar
Was the crank turned down to a smaller diameter? If not you don't need the oversize bearings. I would get a manual and plastiguage to determine your clearances. Follow a manual and you can get it back together and would be more satisfying. If your not comfortalble with it go ahead and have it assembled by a shop.
Old 05-22-2007, 06:58 PM
hogie9ll's Avatar
Smile
yes the crank was turned .025 over and the cyinder walls were borred .030 over...
Old 05-22-2007, 06:59 PM
hogie9ll's Avatar
Smile
i just dont want to f$%# nothing up!!!
Old 05-22-2007, 07:33 PM
TNRabbit's Avatar
Did you put some type of lubricant on before you tightened the crank journals?
Old 05-22-2007, 09:16 PM
BC_4runner's Avatar
The same thing just happened on my rebuild turns out it was the thrust washers
Try taking it all apart and LUBE it up real good make sure you get lots on those thrust washers
Old 05-23-2007, 08:50 AM
hogie9ll's Avatar
heck with it, went in shop this morning!!!
sandyota
02-04-2021 11:16 AM
CanRunner
07-20-2015 01:29 PM
redneck17
07-17-2015 07:44 PM
ZONAYODA
07-13-2015 07:17 PM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: crank wont turn
