Crank shaft pulley loose
I think its a crank shaft pully, but im unsure.
I got a video. http://www.youtube.com/watch?v=3G6UN...1&feature=plcp
What it that, how do I fix it.
don't forget to buy a NEW CRANKSHAFT PULLEY BOLT!! hhahaa! don't re-use your old one and torque it correctly.
I found a new balancer for my 3.4 at toyotapartscheap.com for less than just about anyone else. They are kinda spendy...
URD or LCE might have some 'performance' ones if you want to go that route, not that much more expensive in some cases. just a thought.
Have you had it come loose or this this just a precaution you are trying to pass on?
aa1911's experience:
https://www.yotatech.com/forums/f2/c...es-off-223084/
Thank you for posting that. That sucks.... lol
Thanks for the replies..
So how bad is it to drive?
I know I should get it repaired as soon as I can.. But would it be something that could eff my truck badly. would I be able to get parts around town?
Also, these aint cheep are they?
Anyone got one their willing to sell me?
http://www.autozone.com/autozone/par...1100_202653_0_
http://www.autozone.com/autozone/par...er=438302_0_0_
Before I buy the wrong thing.
Is this what I might need.
Since you are already in ther and have the balancer out, you will want to consider replacing the front main seal.
When mine went, it had like 150K miles. I replaced my belts and seal with new only because it was already part of the stuff taken off. I am not afraid to do more maintenance now if it saves me a headache later.
CS pulley is the hard part, do what ever you can while youre in there! And it is blue loctite for your bolt, the 5vz's use red hi-strenth and more torque for some reason....?
I have one that I would give away free but if you saw my thread, you will see it is not wanted by anyone other than someone who needs a really heavy paperweight!
Hope you get her fixed up, lot's of help on here.
and thanks for posting my CS debocle link up for him already rworegon.
I would 'agree' that an old bolt will work most of the time (as that is what usually happens anyway) but even with loctite and torque, why take a chance? the FSM calls this a 'non-reusable' part like a gasket. wise advice is all I will say.
I believe the washer on the CS pulley is concaved so that it does help keep pressure on that shaft rotating a billion times a minute, once you take it off and re-install, you just lost that extra grab.
loctite, torque, loctite, torque......
anyway, I'll let you get back to the task at hand....
So is there any other name for the Front main seal, I tried to get one but they have no results for them. And after reading about leaks Id like to do it as i down there.
Seal, Oil (For Timing Chain or Belt Cover)
You may need to adjust settings for your rig:
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
http://www.toyotapartseast.com/Page_...2261,2262,2263
Something like in this first post, assuming your pulley has a pair of holes that the bolts can thread into:
https://www.yotatech.com/forums/f116...l-tool-186081/
and once you are holding the pulley, a 1/2" breaker bar does the trick for me on the crank bolt.
