Crank pulley removal
Old 02-12-2012, 07:33 PM
AK01Runner's Avatar
Has anyone had any luck removing the crank pulley without the SST? I got the bolt loose, just need to get the pulley off.
Old 02-12-2012, 08:14 PM
ksti's Avatar
Go to search at top of page and type in (Remove Crank Pulley 22re)
Old 02-12-2012, 09:00 PM
AK01Runner's Avatar
I'm not finding anything on removing the pulley, just a million posts on the bolt. That was easy.
Old 02-12-2012, 09:29 PM
toyota4x4907's Avatar
Weird, the pulley just kind of "fell off" when I broke the crank bolt loose on my 22re....
Old 02-12-2012, 09:57 PM
AK01Runner's Avatar
Mine is on there solid. I tried gently prying on it with no movement. Tapped it with a rubber mallet a few times and nothing. I'm hoping I dont have to buy a tool to get it loose
Old 02-13-2012, 06:18 AM
snobdds's Avatar
They should just slide off. No puller is needed. If really on there tight, spary some PB Blaster on the crank snout and let it soak it.
Make sure the key way is not bent up and is preventing it from letting it come out.
Old 02-13-2012, 06:57 AM
thedrewski86's Avatar
Mine was pretty dang tight but I gave it a few whacks around it's perimeter front and back and it came right off. Rubber or wooden mallet would be ideal. The real trick is to keep at it from every angle as it will "rock" off after awhile.
Old 02-13-2012, 08:15 AM
scope103's Avatar
The key is a woodruff key, meaning it's flat against the pulley and arc-shaped against the shaft. If the key starts to move with the pulley, it will slide up the arc cut in the shaft and jam the pulley.
You can see the end of the key; VERY gently tap it in. If it moves, that might be your problem. If it doesn't move with very gentle tapping, leave it alone.
Old 02-13-2012, 08:04 PM
AK01Runner's Avatar
Loaned a crank pulley from the neighbor, came right off with that. Key is straight and attached.
Old 02-13-2012, 08:07 PM
AK01Runner's Avatar
Both my Timing chain guides were broken. The grooves in the TC cover were deep.
I'm Converting to the LCE dual row timing chain.
Blamalam
03-12-2022 07:34 AM
TJWilly
07-31-2015 02:05 PM
yoterr
07-24-2015 04:29 AM
redneck17
07-17-2015 07:44 PM
dinks07
07-15-2015 05:34 PM
Quick Reply: Crank pulley removal
