is the crank bolt left hand threaded - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 09-25-2008, 06:42 AM   #1
Junkers88's Avatar
just what the title says, on a 22re in an 86 pickup. I ask because my oil leak is worse and last time I tried this I couldn't get the bolt to break loose. I'd hate to find out that I've been tightening it this whole time.
Junkers88 is offline   Reply With Quote
Old 09-25-2008, 06:51 AM   #2
mt_goat's Avatar
Nope....
mt_goat is offline   Reply With Quote
Old 09-25-2008, 07:14 AM   #3
ozziesironmanoffroad's Avatar
use an impact gun to break it loose. they are a PITA to break loose by hand, you have to use the starter to break it loose by hand. with a air impact it comes right off.
ozziesironmanoffroad is offline   Reply With Quote
Old 09-25-2008, 07:50 AM   #4
rustypigeon's Avatar
I used the starter trick to get mine off. Put a breaker bar on the bolt and lay it across the drivers side frame rail. Disconnect and ground the coil, then bump the starter in short intervals. Mine was loose on the first try.
If you go to this website on replacing the timing chain, the first thing they show you is how to get the bolt off the crank using the starter....
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
rustypigeon is offline   Reply With Quote
Old 09-25-2008, 09:05 AM   #5
BigBluePile's Avatar
lock the hubs, put the tranny in gear, transfer case engaged, jam the brake pedal to the floor, chock the wheels, socket/breaker bar/pipe. Get er done.
BigBluePile is offline   Reply With Quote
Old 09-25-2008, 05:38 PM   #6
slacker's Avatar
lefty loosy ... righty tighty
slacker is offline   Reply With Quote
Old 09-25-2008, 07:19 PM   #7
crolison's Avatar
The only time i deal with left hand threaded bolts is at work with turbine foundation bolts
crolison is offline   Reply With Quote
Old 09-25-2008, 07:21 PM   #8
jason191918's Avatar
Quote:
or oxygen tanks or trailer jacks or the left side of my dad's 54 international pick up wheel studs (the right is right hand threads... )
jason191918 is offline   Reply With Quote
Old 09-25-2008, 07:39 PM   #9
wardriver's Avatar
Or bolts from France...
wardriver is offline   Reply With Quote
Old 09-25-2008, 09:44 PM   #10
drew303's Avatar
I've never had to use a starter to break a crank bolt and I've taken many off... I took one off tonight with the engine on the stand. Though in tonights case I am rebuilding the 22r so i let the timing chain jam on the sprocket.
All you need is the truck in gear (or some way to keep the crank from turning whatever method you use) and a breaker bar and some muscle. I've never seen one so tight it wouldnt come off. Get a longer cheater bar! =)
oh and its threaded normal.
drew303 is offline   Reply With Quote
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
Another timing chain question thefishguy77 Newbie Tech Section 10 07-30-2015 11:59 AM
EGR Cooler Plate Torque Values? Snort 86-95 Trucks & 4Runners 1 07-09-2015 04:58 PM
2000 camry wont start Huntingtruckcletus Other Makes Cars/Trucks 0 07-08-2015 06:26 PM
Has anyone else ever had this problem? Badger62811 Off Topic Talk 2 07-05-2015 10:17 AM
Tags
4runner, 92, 93, bolt, brake, crankshaft, hand, left, loose, pick, pulley, thread, timing, toyota, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
