Cracked head between valves 3vze, need input
91 4runner blew a headgasket. Removed the heads this morning and found one of the cyl's with a horrible looking crack between the valves(see pics). I have a appt on monday to take the heads in to be pressure checked and surfaced but not sure if this head is toast or not?? Any opinions?
I see a future for that head casting in aluminum cans. In six months I might be drinking my favorite beverage from a can made from that aluminum.
Another guy just posted up with some head problems, he says that he is going to get a set of reconditioned heads for $535 from National Cylinder Head.
Seems like a great price, maybe too good to be true. I paid close to 1k to have mine reconditioned in town a few years back. That was with new valves, valve job, but re-using the cams.
Good luck.
Good luck.
I have located another engine locally with a 157,000 miles before a rod bearing went bad. I am thinking of buying this engine to salvage the heads. What is the average price of a valve job on the 3.0 heads?
I paid $200 a year and a half ago per head for:
new exhaust valves
new exhaust guides
new exhaust seats
intakes reground
head surfaced
all new valve seals
valves adjusted with proper fitting shims (I gave them the heads with the cams in place so they could adjust the valves)
new exhaust valves
new exhaust guides
new exhaust seats
intakes reground
head surfaced
all new valve seals
Good luck.
Good luck.
WHAT? i paid $680 for mine to be worked on with new valves and cams.
Update - Located a used set of heads and took them in for a valve job and to be surfaced. Replaced the timing belt, idler pullies, water pump, cap, rotor, wires, etc. Took it in to be smogged and passed with flying colors, majorly relieved. All is good now.
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
