Thread Tools | Search this Thread | Display Modes |
#126 (permalink) |
It sounds like you definately had an air bubble in the cooling system. It is very common with Toyotas. Yours has burped from the sound of it, thats what happened when the heater started blowing hot as the coolant finally reached the heater core. You will need to add more coolant now, but it should be good to go. In the future, if you evr completely drain the system again, jack up the front of the truck a foot or so , then remove the rad cap and run it up to operating temp. That usually does the trick to remove the trapped air.
The idle situation might only be related to the lack of coolant. If the coolant temp sender is not sending a valid signal, the ecu gets confused and will make it run weird. On my old pickup with a 22re, I had a slow coolant leak that I never did get around to fixing. If I forget to check it and the level dropped far enough, it would idle really weird. I would not suspect vac advance for that problem, but I'm not sure about the fuel pressure regulator.
__________________
Do you think Einstein walked around thinking everyone was a bunch of dipsticks? Idiocracy (edited for family friendly viewing) |
| Sponsored Links |
#127 (permalink) |
I would hope it is something that easy about it idleing weird but I suspect that isn't it as it has done it the whole time. But like I said last week once it warmed up it did just fine so I will have to keep trying things I guess.
The only SERIOUS thing I'm worried about now is the oil pressure.
__________________
Addicted to all thing automotive. 1956 Ford F-100 (Cummins 4bt) 1968 Dodge Power Wagon (Slant 6..no plans yet) 1971 Toyota Land Cruiser (Soon to be OM617) 1992 Toyota 4-Runner (3.Crap engine..wish it was diesel) 1997 Ford F0250 (Power Stroke) 2006 Volkswagon Jetta (1.9L TD)..."Wife's Ride" |
#128 (permalink) |
At first, there was an airlock, probably in the area of the coolant bypass manifold at the rear of the intake. That's where to cts is located. Now, hopefully it is just low enogh that the sensor still isn't getting a valid temp reading. That's my optomistic view of what's going on anyway. I hope it really is as simple as that, because you have been working your a$$ off trying to get this thing drivable.
The oil pressure is certainly a concern. You need to check it with a manual gauge. I know that Harbor Freight sells a oil pressure test kit for $10, or you can borrow one from Autozone or equivelant. You may need to adapt the tester to fit the metric oil pressure tap on the block, but I have no idea what size and thread pitch the hole is threaded with. I would just use the hole in the block where the current pressure sender is located near the oil filter. How did you modify the oil pickup?
__________________
Do you think Einstein walked around thinking everyone was a bunch of dipsticks? Idiocracy (edited for family friendly viewing) Last edited by zlathim : 08-29-2008 at 08:12 AM. |
#129 (permalink) | |
Quote:
Also keep in mind, oil pressure is a lot like blood pressure. High can be worse than low because it could mean there is a blockage somewhere or the oil is too thick to flow good. What you want its good oil flow.
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx Last edited by mt_goat : 08-29-2008 at 08:17 AM. |
#130 (permalink) |
The engine I was working on that I didn't immediately replace the top bellhousing bolts in ended up needing head gaskets. (got a used engine that had a blown HG) After I had the heads and exhaust crossover off, it was a simple matter of reaching down and putting them in with my fingers. A wrench tightened them right up. It was the one bright spot in the whole miserable project and my laziness finally paid off!!!
__________________
Do you think Einstein walked around thinking everyone was a bunch of dipsticks? Idiocracy (edited for family friendly viewing) Last edited by zlathim : 08-29-2008 at 08:18 AM. Reason: spelling |
#131 (permalink) |
Thank you for the post about the oil pressure sender. Hopefully that is the case. it was in the middle and low end of the stick even though I put 5 full quarts in the thing. So maybe it was just low or it is possible since the idle was so low 3-500 RPMs that at idle it wasn't enough to keep the pressure up as I know once it got to 2K RPMs the pressure was right in the middle.
I got to thinking about the coolant Temp sensor and you may be right. At very first it never idled. I ran the thing and added water. Then I let it warm up and it finally fixed itself and ran well. Then again I started it up this time and it ran crappy but if finally burbed. We will see. I try to be optomistic as much as possible but sometime As far as modifying the oil pick up I had to change oil pans and hence the pick up on the engines as the other came from a 2WD truck. in order to get the oil pickup tube to fit I had to cut off the mounting brackets on the bottom so it would fit. I don't think there is any leaks around the actual spot I bolted it on but that is always a possibility as well I guess. We will see. It just needs a bit more tweaking. I'm thinking that it may be time for some new plugs and wires as well as who knows when those were changed and this thing has seen a lot of previous mudding and abuse the last few days with me tinkiering with it. I think I might head into town tomorrow to go screw around with it.
__________________
#132 (permalink) |
That wouldn't be good. The pressure right in the middle at 2K RPMs sounds pretty good to me, especially if the oil is hot and thinned out.
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx |
#133 (permalink) |
So, is the fuel issue taken care of? Forgive me if you already mentioned it, I can't remember.
__________________
#134 (permalink) |
Yes,
I think I mentioned it in the other thread. Maybe not though. It turned out to be the stereo system the guy had installed. I had him bring me the 6 disc CD changer and when I plugged it in no problem..when I unplugged it no dice. So apperently the way they tapped into that thing if the CD player is not plugged in you go NOWHERE. Hopefully nobody ever steals the thing. I had 2 stolen from me while in college. The second time I wasn't out of my car more than 3 minutes. I could still smell the marijuana in the cab comming off the guy. LAMO. So I have an extra good fuel pump if anyone needs one. I've been painting on my 56 Ford today trying to get it finished up so I can turn my attention to rebuilding the engine for it. I have to work on our Derby Demo car at lunch so that only leaves me about an hour after work each day to work on the 4-runner. My goal is to have it registered and in my driveway at home by Friday though.
__________________
Addicted to all thing automotive. 1956 Ford F-100 (Cummins 4bt) 1968 Dodge Power Wagon (Slant 6..no plans yet) 1971 Toyota Land Cruiser (Soon to be OM617) 1992 Toyota 4-Runner (3.Crap engine..wish it was diesel) 1997 Ford F0250 (Power Stroke) 2006 Volkswagon Jetta (1.9L TD)..."Wife's Ride" Last edited by addicted56 : 08-31-2008 at 12:58 PM. |
#135 (permalink) |
FINALLY FINISHED
Well it is finally done. I spent another 30 minutes on it before work and then another 30 after work. The source of all the problems of the poor idle turned out to be one vacume line. It was one of those in the group of 3 that comes out of the that little black plastic piece on the passenger side. The one that goes down to the red connector on the passenger fender (not the one with the plastic filter looking thing, or the one that T's and goes to the firewall). Anyway after taking every single thing off including the fuel return that was the one that fixed it. It had to be the very last one of course. So after all that trial and error I have a extra fuel pump and a circuit opening relay if anyone needs one. Will probably hold onto the relay though. So the Coolant temp is perfect, the oil pressure is just fine, it idles right around 800 RPM, and the surging problem on deceleration is all gone. It sounds great with the aftermarket intake and the exhaust half rotten. Power is better than I remember as well. But then again It might be the bad name it gets on here. But I was very happy. I should have it registered tomorrow and will drive it home if I can. That way I can finish the small things clean it out and button it up. Next battle is the rear window motor but I think it is fine. I just found out that it was undone when they replaced a broken rear window and never put back together. Hopefully it works.
__________________
#136 (permalink) | |
Quote:
I'll bet that you slept real well last night knowing that all is right with the inner workings of the 4runner. Kudos to you on a job well done. ![]()
__________________
#137 (permalink) | |
Quote:
__________________
#138 (permalink) |
Yes I am glutting for punishment. I have an addiction hence the name. I really do need to start a 12 step program. Maybe whittle it down to just a couple.
I did sleep well. It would good to know that it is running great and will be done in no time at all. As noted in another thread I found an ARB Airlocker for it and I'm going to try and install that in awhile if I manage to get it. Then the lift and tires, and the list goes on and on and on. Might have to get rid of the other projects though to fund it. Thank you again for all of your help on here. I probably could have finished the thing 3 weeks ago if I had just drug it home in the first place and once it really came down to it and I got the fuel problem figured out it really only took about 2 hours to clean up all the small mistakes. Again thank you and I will be seeing more of you all on here soon.
__________________
#139 (permalink) |
No problem! I'm glad it all came together for you. I'll look forward to reading about your future mods.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cracked head.... | orbital02 | 86-95 Trucks & 4Runners | 13 | 02-13-2008 01:21 PM |
| cracked downpipes? | eighty5yota | 84-85 Trucks & 4Runners | 5 | 10-06-2007 04:30 PM |
| block cracked | tampabayota | General Vehicle Related Topics (Non Year Related) | 6 | 04-13-2007 07:50 AM |
| Cracked windshield. | progress4m | General Vehicle Related Topics (Non Year Related) | 13 | 03-04-2006 12:20 AM |
| Cracked Mirror | kawicowboy | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 11-17-2005 09:56 PM |
