Correct Aisin clutch master cylinder 3vze 4runner 1989
Hey all i found out my clutch master cylinder is leaking so i am looking on amazon to replace it with another aisin unit. Problem is amazon and rockauto seem to think it needs a cmt-005... the one that is in the truck is looks a lot more like a cmt-038. Which should i go with?
I am also looking to do the slave at the same time and looking to use a crt-004. Does this seem right?
Thanks for any advice.
If your 4Runner has the original trans , clutch etc.
The thing is one never knows what might have been done.
your going by the technical specs of the different parts ??
It should be CMT-005 Master
CRT-004 Slave
While your doing this may as well do the hose as well.
I always look up Aisin Parts on the Aisin Aftermarket website.
CRT-004 Slave
Yah, i found out the hard way someone gave me landcruiser brakes at some point in the cars life. I'm thinking that i might just go with the cmt-038 because it is working.
Is there a way to tell which slave i have? Unlike the master they all look the same... does it matter?
Joa
10
11-05-2015 10:53 PM
