Coolant temp sensor connector
Trying to locate a new coolant temp sensor CONNECTOR (3VZE) as mine broke the the locking tab when I was removing it due to a headgasket replacement. Has anyone had any luck in finding one of these. The nearest I can come up with is a
Motorcraft WPT-410
but it is awfully expensive at 27 dollars and still do not know if it has the correct dimensions. The locating tabs and pin arrangement are all in the correct location.
Motorcraft WPT-410
Thought about that TN but would like to use as a last resort, would prefer a new connector. The motorcraft one is used on many fords so it might be JY searching time. The One I pictured was used on taurus's from 96 to 98 so they should be pretty common.
nframe
3.4 Swaps
08-16-2015 09:03 AM
Poncho0206
07-10-2015 06:21 PM
