coolant spitting out of radiator
so i just flushed my radiator with some new 50/50 coolant, first drive i took it on i got spitting of coolant out the radiator cap along with some steam. First of all, i dont think my cap is that great, that could be one culprit. Could there just have been some air trapped in the radiator that was causing pressure? should i run it with the cap off for a while?
Just let it sit and run with the cap off at idle. You can tel when the tsat open the fluid will flow thru,then stop when it closes. when it opens it may get low just topit off and let it cycle thru again and see what it does. a few cycles at idle with the cap off and topping it off when the tstat opens you should be good. Then put the cap back on and see what you got.
like if i hit the throttle a little bit the water goes up and down.. but it doesnt seem like its circulating. which is why im starting to think the t-stat is screwed.
the1998sr5
15
07-14-2020 08:35 PM
JaredL
03-28-2016 09:08 PM
_Nicco_
09-21-2015 03:06 PM
TJWilly
07-31-2015 02:05 PM
