coolant level keeps dropping
so i have a 1986 toyota with a 22r and the coolant level just keeps dropping. i will top it off and it slowly goes somewhere. theres no white smoke or anything so i dont think the headgasket is going. the engine was just rebuilt a couple thousand miles ago also.
and another thing is my heater doesnt get very hot. are these two related at all?? any help would be great. thankyou
I've got the same issue, do you smell coolant every once in a while? My issue was/is that the dang over flow bottle has a crack in it and when the rad/fluid gets up to temp (after topping it off cold) it deposits the extra coolant into the bottle and it leaks out. Took me months to find this out.... now all I need to do is seal the damn bottle.
I don't know much about the lack of heat although mine is the same way.... You and I might be chasing the same issues.
Pull the over flow bottle and just wash it out, I think it's 2 bolts that holds it in there. You might have a crack or it might be coming out the top.
Blamalam
03-12-2022 07:34 AM
Tacoma1313
08-17-2015 05:44 PM
Shagool22
08-14-2015 12:24 AM
