Coolant level confusion
Old 11-07-2009, 10:34 AM
Fo by Fo's Avatar
I consider myself fairly knowledgeable about cars but checking the coolant always seems to confuse me. I have a 91 4runner v6 4x4 manual. Right now the engine is warm and the level in the over flow tank is nearly empty. Is this normal, or should I fill it up? From what I understand the coolant normally in the overflow tank gets sucked into the radiator to help cool the engine when it warms up, right? The coolant level should be good as I checked it a few weeks ago, and after inspecting all hoses, caps, water pump I don't see any leaks. Thanks for any help guys.
Old 11-07-2009, 12:04 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
The expansion tank serves a few different purposes, but that is one. I think you're fine.
Old 11-07-2009, 12:05 PM
thook's Avatar
Here's a good explanation..........
http://www.carpartswholesale.com/cpw...flow_tank.html
Old 11-07-2009, 12:12 PM
thook's Avatar
Well, dang.............that's a good one, too. <<tip, tip>>>
Old 11-07-2009, 12:41 PM
LITLRED's Avatar
Yota4 X2
So if your expansion tank was full (or 1/2 full when cold) a couple weeks ago and now its empty then you have a leak. Or it is possible there was air in the system that got burped out which created a vacuum and sucked dry your tank.
Old 11-07-2009, 12:48 PM
mic
mic's Avatar
yes anytime the system is purged of air (burp) it will suck in more coolant from the overflow tank
Old 11-07-2009, 01:13 PM
PCE91V64x4's Avatar
I would make sure you are checking the level consistantly and make sure you have a good rad cap. If you check the level each morning when the engine is cold you will know after some time if there is a leak or not. As stated above, the min/max level in the expansion tank is for a cold engine, so checking the expansion tank when the engine is hot is meaningless.
Old 11-07-2009, 03:04 PM
Fo by Fo's Avatar
Thanks for the help guys, I'm definatly going to look into this. When I refilled the radiator after getting it repaired I had the cap off and the heater on with the engine on to burp the system, and I've already had the headgasket recall done. I don't see any leaks so I hope it isnt another internal leak lol. Please, pray for me, lol jk
Old 11-07-2009, 03:31 PM
peckinpah's Avatar
I am having a similar problem. Ever since I did my timing chain about two moths ago, I have had to refill my coolant reservoir probably three times. So assuming i do have a leak, what are the likely culprits?
Could it just be a bad radiator cap? I replaced all my hoses and none of them show any signs of leaking. And the I see no evidence of leaks around the timing chain cover, though I suppose these might be hard to see.
Old 11-07-2009, 03:53 PM
Fo by Fo's Avatar
As far as I know, (feel free to chime in if I am wrong guys), If no external leak is visible then it would be an internal leak, ie blown head gasket or something else serious. It would be a good idea to pressure test it, I did that about a month ago and found my radiator leak, but with this coolant situation I may need to do it again. Either way I am going to check and refill it when my engine is cold and go from there.
choppe777
05-16-2016 08:00 AM
_Nicco_
09-21-2015 03:06 PM
LotOMiles
09-14-2015 11:45 PM
Dparr2ndgen
09-08-2015 01:06 PM
zz_denis
09-06-2015 03:43 PM
Quick Reply: Coolant level confusion
