Coolant leak detectors
Old 11-01-2007, 11:08 AM
rdharper's Avatar
Any have any luck using a coolant leak detector? Do they work?
I'm looking at Mastercools 53351 which includes a UV detector and multiple adaptors and dyes, including coolant dye.
Old 11-01-2007, 08:27 PM
longhungsilver's Avatar
best thing i find is a cooling system pressurizer.. just pressurize the system and look for the leak.. green or red coolant is pretty easy to see
Old 11-01-2007, 09:36 PM
86tuning's Avatar
Yup. If you use toyota red coolant, you'll see a trail of pink fuzzies where the seepage comes from.
Pressure tester is your friend.
Old 11-01-2007, 10:03 PM
slater442w30's Avatar
we have had good luck with the coolant dye in the shop when the pressure tester just wont show where its going, pressure tester is very effective though
Old 11-02-2007, 07:27 AM
rdharper's Avatar
Anyone detect a dye all the way to the exhaust?
Blamalam
03-12-2022 07:34 AM
SubiKing
08-21-2021 03:57 AM
WellsR
12
07-31-2015 03:27 PM
itzmywife's
07-25-2015 04:55 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: Coolant leak detectors
