Coolant Leak 3.0
Coolant Leak 3.0
Hey guys,
I have a small coolant leak that appears to be coming from the air conditioner pump. From what I can see the bottom of the pump seems to be where it starts from, and then it just trickles down to the street. I dont have any Engine troubles, or hard starts, I have 150,500 miles on my 3.0. If I take pictures maybe you can get a better feel for what to diagnose. Any help would be great.
No white crap in my oil cap or anything. No smoke on startup also.
Thanks guys
Thanks guys
Coolant Leak
Hey guys,
Thanks guys
Thanks guys
There is also a coolant tube that crosses from the frt to the back of the motor under the upper intake that "might be leaking and running down and showing itself at the compressor , alot of "maybe's" , if it were me I guess I might try a pressure test on the coolant system with the motor not running and try to find from there or pull the shroud , radiator , fan and then the timing cover to get a "good" look at the pump and the freeze plugs as well as that corner of the head .
Outside of that just get a powerful light and follow the coolant trail up and you will find it , just remember that with the fan and other factors that the leak may not be straight up from there , it could be running along covers and such before it actually goes down to drip .
jasonty
41
12-23-2018 01:00 PM
WellsR
12
07-31-2015 03:27 PM
itzmywife's
07-25-2015 04:55 PM
Avenged
07-09-2015 07:55 AM
