Coolant issues
Old 12-17-2009, 07:02 PM
87brute's Avatar
Coolant issues
I have an 87 yota with the 22R and I am new with yota's. My coolant resevoir keeps going dry and before you think I am an idiot ill tell you that the resevoir does not have a leak, the radiator is not leaking and my oil level shows no sign of coolant. The truck runs amazing, I have no issues other than the coolant dissapearing. Please help...
Old 12-17-2009, 07:53 PM
flyingbrass's Avatar
How fast are you losing coolant? Is your radiator cap in good condition?
Old 12-17-2009, 07:55 PM
87brute's Avatar
well I went through the entire resevoir in a week and a half and it is a brand new radiator cap
Old 12-17-2009, 08:21 PM
sb5walker's Avatar
Coolant pressure test. Pull the air hose off the throttle body and look for seepage from the IAC/AAV (idle air control/auxiliary air valve - the cold idle up valve). If you don't see the leak, try a leakdown test.
Old 12-17-2009, 08:39 PM
I suppose that's another question: is it a 22R or 22RE?
22R = carbureted
22RE = fuel injected
If carbed, while you're searching for leaks check under the intake manifold. A coolant hose runs under it.
Old 12-22-2009, 02:51 PM
87brute's Avatar
It is a 22R (carb). I think the guy that sold it to me knew that it had issues because while goin threw some basic maintence I noticed that the coolant cap had no pic-up line into the resevoir. I thought that was kind of fishy. but I will try that pressure test that you had mentioned and the other places to check under the manifold and let you know what is up...
Thanks for the help
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
WellsR
12
07-31-2015 03:27 PM
ddg71
07-24-2015 01:24 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Coolant issues
